M52 b30 stroker rebuild back on the road
87mtech27
Some serious money being spent
Sorted
How sad
thread cleaned again , cheers Iain .
+ a yard full of scrap turds
HartgeH27
Sorting.
should be getting the car back today ......4 days turns into 2-weeks , typical bodyshops
the propshaft is ready .
not long now
not long now
another day late but who cares it's done and back home , i will be spending the weekend mostly ....... down the garage !
BHadley
Nice finish, can't rush ledder as it's said on here ....
slideout318i20 wrote:Nice finish, can't rush ledder as it's said on here ....
cheers mate , i did have a deadline of 9th may to have it mot'd and taxed for a big meeting at croft race circuit , i wouldn't of been racing the car anyway and just attending but that's out the window , and i'm just gonna plod on taking my time till it's ready now , no pressure
upgrades the e36 rack to e46 clubsport
fitted a new bonnet release cable and got the engine bay looms back where they all go ,still got clutch ,brake lines and servo to fit then it's ready for the engine/box sometime next week
jmc330i
Looks clean, good work
The pics aren't too clear on my phone but is that steering joint welded?
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
jmc330i wrote:Looks clean, good work
yes it is , i've been running it since the m50 conversion package 4 yrs ago and the past 5 mots .
jmc330i
Friendly MOT tester?magpie wrote:jmc330i wrote:Looks clean, good work
James
'91 325i Sport
'91 325i Sport
no ,i've used 4 different testing stations in 6 yrs . mot is due now as it happens .jmc330i wrote:Friendly MOT tester?magpie wrote:jmc330i wrote:Looks clean, good work
jmc330i
Pretty sure a welded steering linkage is an MOT fail
Anyhoo, good work with this. Trying to get the motivation to get both mine done lol
James
'91 325i Sport
'91 325i Sport
Cheers Jim, i'll change it should it become a problem .jmc330i wrote:Pretty sure a welded steering linkage is an MOT fail
i had no motivation today ... it was fookin freezing up here
[youtube][/youtube]
hotross
Is it on youtube?
I cant view it
Its saying, Install Flash and it won't install
I cant view it
JF008
Yipper
hotross
I just see the vid. Did you rebuild it from scratch?
New Rings and so on?
Id like to know the cost for then i do mine
read the thread from page 47 when the engine build starts fella .hotross wrote:I just see the vid. Did you rebuild it from scratch?
Cypriotgeeza
I think i have to echo your wise words to me all them months ago Mick :
Top work as always!
I couldn't agree more with this!magpie wrote:nowt beats the first fire up of an engine conversion ,some even save it for the night time with no zaust manifold on![]()
videos of the first start up be it day or night time are obligatory btw
the 2nd best thing is hearing the electric fan kick in
Top work as always!
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
appletree
Waahoo!
spook
- League two here we come !!!
Top work Mick
hotross
What seals did you use Elring ?magpie wrote:
Craig took the cylinder head home to do the valve stem oil seals and i'll be dropping the block and other parts off on Monday .
the only thing getting in the way is Christmas
craigieeb
M50 Turbo!!!
I shall say no more
hotross
Where did you get them from?craigieeb wrote:Yephotross wrote:What seals did you use Elring ?magpie wrote:
I can only find FEBI ones for some reason...
Green seals or black did you use?
craigieeb
Infact, thinking back they might of been febi actually, and I'm sure they were black.
M50 Turbo!!!
I shall say no more
elring or febi are both good parts
hotross
Cool please to hear that, as i bought the febi ones.magpie wrote:elring or febi are both good parts
Did you have to use coils in the treads or was it ok?
I seen many posts about one or two pulling at the last 90 degree even with a good non-over heated block.
have a read from page 36 when i fit a replacement m52 that had a f00ked head gasket , that engine [ m52 b28 ] was in my car for two years and is under my work bench as a spare, still runs spot on
http://www.e30zone.net/modules.php?name ... &start=875
this link takes you to the headgasket problem engine . ^^^^
finally got the gearbox mounted up and the propshaft on ..........
managed to bleed the brakes up Aaaaand ........put it away till next time
[youtube][/youtube]
[youtube][/youtube]
hotross
Jesus.. you not had much luck..magpie wrote:have a read from page 36 when i fit a replacement m52 that had a f00ked head gasket , that engine [ m52 b28 ] was in my car for two years and is under my work bench as a spare, still runs spot on![]()
Did you manage to measure the valve to piston clearance by any chance while you was doing the build.?
That's something i'd love to know..
B30 pistons seem to be 1.8mm below the block deck.
As then a standard 1.75mm can be used ???
And up the compression on a skimmed head ?
M54B30 gaskets are 0.70mm if i recall
your better off starting your own build thread mate , you'll get plenty of help with your questions like i did .
i know when i had the m52 head skimmed [ on the 2.8i engine] it had 12 thou took off it and was fine with a standard gasket .
