Finally got the MS built and in the car. Got a few questions but first pictures, we all like pictures:
Mainboard
55pin Breakout board
Crimped and heat shrink'd the cable for the IAT
Re-used the connector from the AFM as I'm trying to keep the factory harness as stock as possible
High quality Chinese air filter
E36 TPS - bit of a bodge but its in tight
Soooo.... TPS, CLT, IAT are all calibrated.
I cant find where to set the following settings from the wiki in Tunerstudio (V2.6.14) can anyone point me in the right direction:
Squirts Per Engine Cycle = highest value so that idle pulse width is no less than 2.0 ms, if possible, and your Req_Fuel is less than 15-18 milliseconds, but more than 6 milliseconds
Injector Staging = Alternating
Engine Type = Even Fire
Tach Input/Ignition Options
Number Of Coils = Wasted Spark (or single coil if single coil)
Spark A output Pin = D14 (again can be sparkA if using the stock transistor).
Trigger Wheel Settings
Tooth #1 angle = 84 Wheel Speed = Crank Wheel
