2 speed fan help
P_VIDDY
Post Fri Apr 24, 2015 8:23 pm
Hi,
Trying to wire up my 2 speed fan.
I have high speed running (and working) through k6 relay.
When I tried to wire k1 relay to run low speed there is only one slot for me to add a wire... 85-ground. The 86 terminal is soldered to the board?
Post Fri Apr 24, 2015 8:29 pm
86 is ground, test light will confirm :wink:
P_VIDDY
Post Fri Apr 24, 2015 8:35 pm
You sure dan? As on the k6 relay 85 was ground? Packed up tools for night so will carry on tomorrow afternoon
JF008
Post Fri Apr 24, 2015 9:31 pm
Only one of the two relay needs a ground added. Well if Dan said it lol but I've wired my fan not long ago and that's how it is :D
P_VIDDY
Post Fri Apr 24, 2015 9:46 pm
Ok that slot must need the wire from the sensor then to trigger the relay. Thanks
Post Fri Apr 24, 2015 10:02 pm
P_VIDDY wrote:You sure dan? As on the k6 relay 85 was ground?
Only because thats the pin you put it on, as I said, test light will confirm 8)
P_VIDDY
Post Fri Apr 24, 2015 10:06 pm
Yeah I'm with it now Dan. Cheers
