air filter heat shield
booomer
Sun Apr 05, 2015 9:05 am
Just started making a heat shield to house my air filter. I used a wire coat hanger to bend to the profile of the inner wing then transferred the shape to some thin ply i had lying around. This is just a template and i'm going to use black nylon 66 (polyamide) which is pretty much the same stuff as all the other engine plastics are made of. I want it to look inkeeping as much as possible. I'll use the rubber seal in the last picture hopefully to seal effectively against the underside of the bonnet in one continuous loop
JF008
Fri Apr 24, 2015 7:12 pm
Nice one, here's what I did with mine: http://www.e30zone.net/modules.php?name ... 21#2773121
jmc330i
Sat Apr 25, 2015 11:07 am
Good work 8) Do you need to try and seal it against the bonnet? You could make a complete enclosure around the filter.
Here's my first attempt, the finished one looked the same but with rear enclosed similar to yours.
The enclosure clipped onto existing holes for the plastic headlight backplate and it curved around the rad etc right down to the chassis rail where two little tabs held it firm.
James
'91 325i Sport
'93 318i touring 16v
JF008
Mon Apr 27, 2015 10:09 pm
Have you made any progress?
