205/50/16 or 205/45/16?
jmc330i
Post Wed Apr 22, 2015 3:59 pm
My touring is currently running 205/50/16s. Wheels are 16x7, but will 205/45 be too small? I will be replacing all 4 tyres.
I'm not sure which will be closest to the standard 205/55/15 and for some reason the online size calculators won't work on my phone.
Another thing to consider is I also have some 16x8 wheels that I'll eventually be using and would like to swap the tyres over to these.
James
'91 325i Sport
'93 318i touring 16v
minesapint
Post Wed Apr 22, 2015 10:08 pm
The closest to standard 205/55 R15 on a 16"rim is 205/50 R16
minesapint
Post Wed Apr 22, 2015 10:19 pm
205/50 R16 will not go on 8j rim.
225/50 R16 will go on 7j & 8j rims
Post Wed Apr 22, 2015 11:50 pm
You'll need 225/45/16 for the same rolling distance, if you go that size on the 8j rim.
WEEMANDANBRITTON
Post Thu Apr 23, 2015 8:28 am
i have 8j rims from a 7 series on my 318 is and they are fitted with 205/50R16 tyres, there's a little bit of stretch but they do fit
Post Thu Apr 23, 2015 9:03 am
WEEMANDANBRITTON wrote:i have 8j rims from a 7 series on my 318 is and they are fitted with 205/50R16 tyres, there's a little bit of stretch but they do fit
Depends what you mean by 'fit', and whether you're concerned about running with invalid insurance or not.
minesapint
Post Thu Apr 23, 2015 6:31 pm
Rav335uk wrote:You'll need 225/45/16 for the same rolling distance, if you go that size on the 8j rim.
Is the wrong answer.
225/50 R16 is near as damn-it the same circumference as your original 205/55 R15.
Whether on 7j or 8j makes no difference to the circumference.
Don't even think about this "stretching" business.
reggid
Post Thu Apr 23, 2015 11:18 pm
nope 225/50/16 is not correct at all its 4% out, 205/50/16 is the closest 16" 205 width to 205/55/15, 225/45/16 is also "equivalent" both are less than 1% different
E30 325is with M20B31
Post Thu Apr 23, 2015 11:42 pm
Easy enough to calculate!
Take 205/55R15 : 15" = 381mm, tyre width is 205mm, with a sidewall height of 0.55 of that = 112.8mm. Total tyre diameter = 381mm + (2 x 112.8mm) = 607mm
16" = 406mm, so the diameter of 225/45R16 = 406 + (2 x 0.45 x 225) = 609mm
Diameter of 225/50R16 = 406 + (2 x 0.50 x 225) = 631mm
Post Fri Apr 24, 2015 12:47 am
Thank You. :P
minesapint
Post Fri Apr 24, 2015 7:36 pm
Rav335uk wrote:
reggid wrote:
minesapint wrote: Is the wrong answer.
Thank You. :P
Sorry Raj, I'm wrong. You're correct 225/45 R16 for the 8j rim & 205/50 R16 for the 7j
Post Sat Apr 25, 2015 10:09 pm
minesapint wrote:
Rav335uk wrote:
reggid wrote: nope 225/50/16 is not correct at all its 4% out, 205/50/16 is the closest 16" 205 width to 205/55/15, 225/45/16 is also "equivalent" both are less than 1% different
Thank You. :P
No probs, and it's Rav btw.
