Fuel pump HELP needed.
Bazo187
Post Wed Apr 15, 2015 11:05 pm
My car is a 1992 BMW E30 318i cab
Broke down two days ago rang up the AA. Turned out to be
The fuel pump, give it a whack and started up.
Need to change it what would be my best bet?
OEM part or aftermarket stuff
And best place to get one plz.
motormanmick
Post Thu Apr 16, 2015 3:49 am
Hello Bazo187
Oem always for that, I went aftermarket once with a fuel pump, it died amazingly just after the warranty period was up. I'm in Australia so can't help with where to buy, cheers.
Bazo187
Post Thu Apr 16, 2015 10:53 am
Bazo187
Post Thu Apr 16, 2015 9:25 pm
The pump you will get from BMW is a complete assembly, but it is a simple job to fit a new pump to your existing frame. The actual pump is the same whether you have a 55 litre or 63 litre tank.
See the latter part of this recent thread: http://www.e30zone.net/modules.php?name ... 2&start=25
Bazo187
Post Fri Apr 17, 2015 12:38 am
Sorted ordered an aftermarket full assembly to make it easier to change. Gona have a crack at it tomorrow.
Cost 80 quid for the new one OEM part was like 150 new and second hand ones looked worse then what I pulled out.
