328 prop
k20trew
Post Mon Mar 02, 2015 2:34 pm
when fitting a 328 manual prop !
guide say reverse centre bearing !
do i fit the e30 centre bearing reversed
or reverse the e36 328 centre bearing ?
thanks for any help
Bristol_Jer
Post Mon Mar 02, 2015 7:51 pm
That bit confused me too, I just offered up the centre bearing and it all fitted fine, didn't need to reverse anything! Make sure you pre-load the bearing when you fit it. :)
k20trew
Post Mon Mar 02, 2015 8:03 pm
Cheers ! I stood and looked at 328 prop on the floor and could not see a the reason to flip it !
By eye it looked like it wouldn't really move the mounts to body on centre bearing forward or back
8O
k20trew
Post Tue Mar 24, 2015 12:02 am
To clear this up as it confused at least two of us 8O
I used 328 manual prop with e30 centre bearing !
E36 centre bearing is too wide for the e30 trans tunnel
Hope this helps someone :cool:
Bristol_Jer
Post Tue Mar 24, 2015 7:42 pm
Sorry yes I should have said more clearly, I used the 328i prop with a new e30 centre bearing the right way round!
Cypriotgeeza
Post Sat Apr 11, 2015 11:31 am
Bristol_Jer wrote:Sorry yes I should have said more clearly, I used the 328i prop with a new e30 centre bearing the right way round!
Im guessing this was a 325i centre bearing?
Im looking to replace mine as it has an e36 bearing on there and the heatshields no longer fit because this bearing sits lower :mad:
Check my M30 build threads:
Bristol_Jer
Post Sun Apr 12, 2015 5:35 pm
I can't remember which e30 one it was, but have a feeling most if not all e30 centre bearings are the same?
Bristol_Jer
Post Sun Apr 12, 2015 5:37 pm
Yep just checked, same as e34 and e32 too :)
http://bmwfans.info/parts-catalog/26121226723/
Cypriotgeeza
Post Sun Apr 12, 2015 10:13 pm
Bristol_Jer wrote:Yep just checked, same as e34 and e32 too :)
Nice one thanx for that mate! :thumb:
Matty-Westside
Post Wed Apr 20, 2016 8:08 pm
Yeah its the e30 centre bearing reversed. Confused me too as I reversed the e36 bearing first! The reason for reversing the bearing is because the bearing mount is offset on the opposite side to the e36 bearing mount. So by reversing it, it lines up better with the e30 chassis.
