bought it with an oil leak a few months back
at first thought the oil was coming from front camshaft seal so replaced it and it was still dripping oil so then moved on to headgasket replaced that and it was still leaking from same place just under the cylinder head on number 1, the corner of the block running down the front and dripping off the sump (also changed the belt and tensioner this time around)
so after a couple of weeks of putting up with leaving oil puddles everywhere i stripped it all again, bought all new gaskets required, had the head skimmed, new bolts it was fine for 2 weeks and now its leaking oil in exact same place
im beginning to get a bit fed up with this now
could the block have warped or something??? i cant see it has but ive had the head skimmed new gasket,bolts, correct torque and its still leaking so only leaves block in my book.
Losing faith might just go buy some euro diesel shitbox
