M20B25 High Idle
Eddie1990
Post Mon Mar 23, 2015 7:34 pm
I have a high idle on my M20B25, it's sitting at about 1200 irrespective of if it's warm or cold.
I've checked for vacuum leaks, and the blue plug is new, so it shouldn't be either of those.
The engine is in my 1977 BMW E21, so there has been some modification to the wiring, but it is all done right, I'm sure of that.
I'm running out of ideas, could it be the TPS, or the MAF or the ICV? If so, what's the best way to be checking them? It failed the MOT on this, so I want it sorting sooner rather than later really.
Any help would be greatly appreciated.
jimbom30cab
Tech 1 freak
Post Mon Mar 23, 2015 7:39 pm
Normally A TPS which isn't plugged in can give a high idle.
There are instructions on testing the TPS in the wiki but I would check it's plugged in and not soaked in oil first.
Eddie1990
Post Tue Mar 24, 2015 12:00 am
Yeah I'll have a look and see tomorrow, thanks.
Post Tue Mar 24, 2015 9:49 am
Simple things first! Check that the throttle butterfly is physically hard against its stop at idle, and isn't being held partly open by a stiff mechanism, a throttle cable that is too tight, or similar.
While you're there, look for any signs that the throttle stop has ever been adjusted since the car left the factory.
Eddie1990
Post Tue Mar 24, 2015 12:59 pm
I noticed this yesterday, the throttle isn't actually stopping against the stop, however I can't be certain the screw is in the original position.
It's not the cable as I've removed it and it still idles a little high.
As I say, I can't be sure on the throttle stop screw.
It's only idling at about 1200rpm when cold, it's not massively high, just a little.
jimbom30cab
Tech 1 freak
Post Tue Mar 24, 2015 1:26 pm
Does the TPS make a quiet "click" as soon as the throttle is opened?
Is the TPS connected?
Eddie1990
Post Tue Mar 24, 2015 1:38 pm
I'll have a check tonight and get back to you.
Post Tue Mar 24, 2015 1:52 pm
If the throttle isn't closing against its stop, the first thing to do is find out why. It may be the linkage holding it open, it may be an obstruction inside the throttle body fouling the butterfly, or it may be that the butterfly is closing fully, and some idiot has been adjusting the stop.
Whatever the reason, this is something that is clearly incorrect, and should be sorted before doing anything else, even if it makes the situation worse or has no effect.
Eddie1990
Post Tue Mar 24, 2015 2:15 pm
Okay, so assuming the throttle stop is wrong, does it need winding back to touch the linkage stop plate? It might not have been moved, but as I say, it appears to be just off the linkage plate, by about 1-2mm
Post Tue Mar 24, 2015 2:18 pm
Find out why and report back.
Eddie1990
Post Tue Mar 24, 2015 8:34 pm
Still can't find anything.
Removing the oil filler cap reduces the idle to about 1,000 but it sounds ever so slightly lumpy. Don't know if that means anything to any of you in the know?
Eddie1990
Post Tue Mar 24, 2015 8:49 pm
Is it possible that the engine is over pressurising because it's plumbed into the E21 brake servo's? This creating a higher pressure in the intake system, and raising the idle?
Seems like a long shot, but I'm just brain storming with you guys
Eddie1990
Post Tue Mar 24, 2015 8:56 pm
When I disconnect the MAF it runs poorly, idle drops and raises rhythmically, almost like a really slow pulse, up and down of the revs.
Eddie1990
Post Tue Mar 24, 2015 8:59 pm
When I very slightly blip the throttle (with the linkage, not the pedal) the revs drop a lot, and it has caused it to stall on one occasion. When I say blip the throttle I mean slightly tap it, sometimes the revs climb momentarily and then dip very low, sounding like its about to stall.
Eddie1990
Post Tue Mar 24, 2015 9:13 pm
Just taken the vent hose off the rocker cover and that lowered the revs, in a similar manner as when I removed the oil filler cap.
BenHar
Post Tue Mar 24, 2015 10:19 pm
jimbom30cab wrote:Does the TPS make a quiet "click" as soon as the throttle is opened?
Eddie1990
Post Tue Mar 24, 2015 10:33 pm
Yeah the TPS clicks when the throttle moves.
Yeah the TPS is connected correctly.
BenHar
Post Tue Mar 24, 2015 10:52 pm
Try taking out the ICV. Block the holes it connects to. If the engine still idles at 1200 the throttle is not fully closed.
If the idle goes down to very lumpy then the throttle is probably correct so clean/replace the ICV.
Ben
Eddie1990
Post Mon Mar 30, 2015 1:08 pm
Engine has now developed a running issue:
http://www.e30zone.net/modules.php?name ... 64#2834064
