M50 vanos engine conversion!!!!!!!!!
ING17
Post Mon Mar 23, 2015 7:32 pm
Fitted a m50 vanos engine to my e30, had to fit an e34 wiring loom as rats chewed through my original one (got told an e34 wiring loom is the same and should work) went by the wiring diagram on the zone. The problem I have is no fuel and no spark? Any help would be much appreciated. Thanks
Post Mon Mar 23, 2015 10:45 pm
Your engine is either immobilised by the EWS system or you have fitted the loom wrong and have no crank sensor signal
Post Mon Mar 23, 2015 11:45 pm
What colour is the label on the ECU?
