e30 rear brakes
deane30tour
Is there a good upgrade to the rear breaks???
Mitchen
ross_jsy
That's a pretty useless link given the question...
Tourings used a slightly larger piston on the fears. Not sure if you would really notice it. WMS do a nice looking rear calliper upgrade.
What have you done to the fronts to make you think you need to upgrade the rears?
jmc330i
BMW Z1 rear discs with E30 M3 rear calipers is a bolt on upgrade. That gives a 282x10mm rear disc, but at 10mm thick it's still a solid disc.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
appletree
Senna has the above set up for sale on eBay
Cypriotgeeza
appletree wrote:Senna has the above set up for sale on eBay
i think the OP was one step ahead of you lolsenna wrote:Brakes sold
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
HairyScreech
The other option is compact or Z3 rear callipers with a disc of your choice (probably a redrilled compact/z3 one for 4 stud people) and they can give 170mm ish or bigger for Z3M bits.
Again still a solid disc, Is vented really needed at the rear? Even e30/compact race cars don't comment on rear disc fade.
We have stock e36 compact discs at the rear of the s50 powered compact and never had an issue.
deane30tour
It's just I have my hydro plumbed in and it doesn't even lock the Rears unless I really pull hard on the wand!
keri-WMS
BUT....if that's not working with std bias, any fix at the rear axle will mean adding rear bias and making the car overbraked at the rear.deane30tour wrote:It's just I have my hydro plumbed in and it doesn't even lock the Rears unless I really pull hard on the wand!
Put a larger master cyl in the hyraulic handbrake or change the leverage?
etouring
I saw some one selling new mini ones on e bay saying they were an upgrade with pics etc
HairyScreech
That would be my suggestion.keri-WMS wrote:BUT....if that's not working with std bias, any fix at the rear axle will mean adding rear bias and making the car overbraked at the rear.deane30tour wrote:It's just I have my hydro plumbed in and it doesn't even lock the Rears unless I really pull hard on the wand!
A lot of people pick a cylinder based on foot brakes and your arms give nothing like the force of your legs.
