Rusty Water????
Tripper
Post Tue Mar 10, 2015 4:39 pm
Hi Zoners,
I'm not quite sure if rusty water escaping from my exhaust is a good sign or a bad one..?
The water in my coolant tank is a bit rusty too..?
What does that all mean?
I don't have any overheating problems, temperature goes up and down as it should.
Any guidance would help a worrying lad as myself..?
Many thanks, Tripper
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Mar 10, 2015 4:59 pm
The wet exhaust means it's winter.
The rusty coolant means you've been very slack in replacing your coolant.
Tripper
Post Tue Mar 10, 2015 5:15 pm
Thanks Grrrmachine,
The slacking on my behalf has been dually noted.
I did have the car off the road in storage for 15 months...
Full service due??
Post Tue Mar 10, 2015 7:11 pm
Tripper wrote:
Full service due??
Coolant change, at least, and hope that the head hasn't corroded too much in the meantime.
How old is the cambelt?
Tripper
Post Tue Mar 10, 2015 7:34 pm
Thanks Brianmooore,
Coolant change it is then, can I do this myself or is it a garage thing??
cambelt is 5yrs or more, change that too?
If it can be a DIY, and guidance?
thanks Tripper
P_VIDDY
Post Tue Mar 10, 2015 7:49 pm
If your asking for how to on changing the coolant then I'd recommend you pay somebody to change the cam belt. Not something you want to 'have a go' with.
Tripper
Post Tue Mar 10, 2015 8:18 pm
I understand the cambelt will require a mechanic P Viddy, how about the coolant change?
Post Tue Mar 10, 2015 8:50 pm
Cambelt change on a M20 is one of the easiest there is, and should be combined with the coolant change, since the radiator comes out to give room to access the cambelt. Water pump should also be changed at the same time, if its history is unknown.
All are easy DIY, but I have to agree with P_DIDDY that asking how to change the coolant doesn't exactly inspire confidence. Buy yourself a Haynes manual, have a read, and see if you feel confident to get stuck in.
You may be a competent mechanic in waiting with just no experience, or you may be like one of my brother in laws, who should never be allowed within ten yards of a toolbox.
Tripper
Post Wed Mar 11, 2015 7:41 am
Thanks Brianmooore,
Is there anything else I should change? I might put a picture up of my engine bay. You experts may notice
Some things I can easily miss...
Anything else will be noted as I'm making a list to ensure my cabby is ticking over for many years to come...
Giggz
Post Wed Mar 11, 2015 11:40 am
Rad, thermostat housing and thermostat...again, if history is unknown.
Any coolant pipes perished or cracked?
^stolen but not forgotten^
Tripper
Post Wed Mar 11, 2015 1:06 pm
understood Giggz!! :)
aimlessrock
Post Wed Mar 11, 2015 1:26 pm
If she is a keeper and the history is unknown i would replace all the coolant hoses whilst you have the access.
Might also be a good time to check the rubber fuel lines in the engine bay as well.
E30 320i Convertible (1989)
190 Mercedes (1988)
HairyScreech
Post Wed Mar 11, 2015 5:11 pm
One thing, once the coolant has gone rusty once it tends to go brown pretty quick for many, many coolant changes after.
Sediment etc gets all over the place and is really hard to get out.
K-seal seems to cause similar problems even if cleaned out (as best as possible, horrible stuff).
Post Wed Mar 11, 2015 6:25 pm
M20s have a little known coolant drain plug, right at the back of the block, under the exhaust manifold. It's a 19mm hex. headed plug, and expect to lose some knuckle skin undoing it, but removing it and flushing water into the block via one of the hoses will help shift a lot of the sediment.
When flushing the system, it's important that you don't force water under pressure down through the heater from the top stub pipe to the bottom.
Tripper
Post Wed Mar 11, 2015 6:49 pm
Wow! Guys information overload!
You all have some serious wealth of knowledge on these vehicles!! :D
Think I need a list...? :D
P_VIDDY
Post Wed Mar 11, 2015 7:39 pm
The zone is great for help and advice. Some top guys on here. Im a BMW specialist mechanic but think I'm on the wrong forum as I work on much newer BMWs haha. My only knowledge of the e30 is from a handful of customers cars I look after and my own of course :D
BHadley
Post Wed Mar 11, 2015 8:14 pm
The drain plug on the block really does make a difference to flushing old water out.
Well worth the fiddling about as Brian says...
Tripper
Post Wed Mar 11, 2015 8:59 pm
Your all Top fellas!!!
All notes taken.. - is there a specific order to all this I should be carrying out in sequence?
Apologies for the many questions - but I'd really like to learn more about my bit-on-the-side... if you guys know what I mean..? winkeye
thanks,
tripper
Post Wed Mar 11, 2015 11:18 pm
Draining the old coolant out is the first thing, and refilling with fresh coolant is the last thing, since for the whole of the rest of it, the cooling system will be in pieces.
