Hi Gert,
I'll try my best to explain what happens. PUTTING THE ROOF DOWN.
1. Lower all windows, open both front roof latches and push roof up.
2. Push the button to lower roof and the rear windscreen section does not lift in order for the horseshoe section to open. So here, I have to manually lift the rear windscreen section AND HOLD WHILE REACHING FOR THE BUTTON TO CONTINUE THE ROOF RETRACTION CYCLE.
3. The horseshoe lid opens, here I can now slowly lower and release the rear screen section, so the roof can be folded away into roof compartment.
4. I usually start and stop the roof retraction cycle so I can ensure the roof is correctly folded in sections and that the screen doesn't have any creases.
5. Once roof has fully folded into compartment the horseshoe closes accordingly.
PUTTING ROOF UP
1. Windows are down. Push button and the horseshoe opens and out comes the roof.
2. But once the roof is out, the rear windscreen section doesn't lift to clear the way for the horseshoe lid to close.
3. Here, I have to stop the sequence and manually lift the rear screen section and hold, at the same time active the sequence again to lower the horseshoe lid and lock.
4. Slowly lower the rear section and pull front roof down and lock latches in place. Then close windows starting with the rears and then the front windows.
I'm not sure if that sound any good - I hope it makes some sense...?
