M52 Nikasil
SAP1
Post Sun Mar 01, 2015 1:31 pm
I'm looking to buy an E36 328i with under 100k miles. If it still has the Nikasil engine should I be worried?
jimmyspeed
Post Sun Mar 01, 2015 2:13 pm
what year is it?
SAP1
Post Sun Mar 01, 2015 2:35 pm
1996
nickso
Post Sun Mar 01, 2015 3:00 pm
If it runs Ok I wouldn't give it a second thought.
'88 e30 328i M52 track bint.
jimmyspeed
Post Sun Mar 01, 2015 3:15 pm
if its a sport the earlier cars came with a LSD which would be a bonus
darkchild
Post Sun Mar 01, 2015 3:17 pm
Its now 19 years old. Assuming its even still on its original block it'll be fine.
Andyboy
Alpina Colada
Post Sun Mar 01, 2015 7:00 pm
Even so, Nikasil engines don't like lots of cold starts - that's what buggered them. So once it's started, try not to switch it off again until it's good and warm.
It may well have had a block swap by BMW in the past. Look at the back of the block below the starter and you'll see either a pear shaped casting lug (nikasil) or a rusty steel tag with a bolt (steel liner replacement).
Post Sun Mar 01, 2015 8:04 pm
Do a compression test if your worried, they still turn up now and again with no compression, usually through auctions
SAP1
Post Thu Mar 12, 2015 11:04 pm
Sorry for the late reply.
Went to look at the car it was a 1996 328i Moordoor.
The body work was decent but when looking at the car the cooling system pressurized and overheated, so I walked away there is plenty 328's out there so onto the next one :D
Thanks for the advice lads :thumb:
Post Thu Mar 12, 2015 11:05 pm
Headgasket FTL :)
SAP1
Post Thu Mar 12, 2015 11:08 pm
Yup LOL, warped head winkeye
