driver door making a loud click on opening and closing
Bally
hi my e30 convertible drivers door makes a loud click on opening and closing approx when half way , it is not the hinges it is the door retaining bar that stops the door once fully open what is this called anyone had this problem whats the fix is it easy or not thanks
BenHar
Try squirting lots of lubricant into it. WD40 to start with then oil once it has freed off.
Ben
Ben
The frame of the retaining strap inside the door has probably broken - common fault.
Easily changed, once the door card is off.
BenHar
If you take the door off, don't undo the hinge from the door as above, just remove the hinge pin. This will save all sorts of fun trying to realign the door when refitting.
Ben
Ben
I am still amazed by the amount of people that remove the hinges to take a door off a BMWBenHar wrote:If you take the door off, don't undo the hinge from the door as above, just remove the hinge pin. This will save all sorts of fun trying to realign the door when refitting.
Ben
Bally
Thanks Brian was right when i open the door i can see the metal strap jolt as it makes the noise thanks
sweep
How do you remove dan with the 4 13mm nuts..DanThe wrote:I am still amazed by the amount of people that remove the hinges to take a door off a BMWBenHar wrote:If you take the door off, don't undo the hinge from the door as above, just remove the hinge pin. This will save all sorts of fun trying to realign the door when refitting.
Ben
Bally
sorted , got part from pacer Pete (thanks ) and as Brian stated the bracket inside the door had snapped easy job to do replaced door cards and gromit for interior light which has sorted interior light , electric window light staying on and alarm issues thanks again Brian
