Possible ews problems ???
Danny-C
Fri Feb 27, 2015 10:34 am
Hi I have messaged danthe waiting on his expertise but hoping someone else has had this problem
I put a new engine in at Xmas as the other give up the ghost had it running and everything's been fine but I haven't had it on the road as of yet. I've come down last night to do a few bits ready for the mot and the battery's gone flat and wouldn't jump so charged over night, it just won't fire up I'm pretty sure its the ews as mine was a earlier one it still has it. There no power at the relays or fuse.
It doest run the fuel pump and running power to the pump it still won't start (but the pump does go) as it's not opening the fuel rail. Does this sound about right? Oh I'm sure you once said the ews box should click which it doesn't either.
Any help would be great
Many thanks dan
Davidchurch
Sun Mar 01, 2015 11:08 am
Was the key left in the ignition when the battery went flat by any chance?
Danny-C
Sun Mar 01, 2015 9:18 pm
Yeah it was :o: :cry:
2 door black leather cards wanted
Front wings new or good seconds
M50 inlet manifold Internal fan heaters/blowers ALL WANTED CASH WAITING
Davidchurch
Sun Mar 01, 2015 10:57 pm
That will be your problem. Get the ews deleted. Will save you a lot or arse ache and to be honest it's not that expensive to get it done.
jmc330i
Sun Mar 01, 2015 11:27 pm
Davidchurch wrote:Was the key left in the ignition when the battery went flat by any chance?
What difference does that make?
James
'91 325i Sport
'93 318i touring 16v
Davidchurch
Sun Mar 01, 2015 11:42 pm
Basically if you keep the key near the chip reader and battery goes flat it drains the key. Happened to me so I had to get the ews deleted and everything was fine again.
Mon Mar 02, 2015 12:00 am
The key chip is charged up as it sits inside the antennae ring
The usual case is the key chip looses the rolling code
jmc330i
Mon Mar 02, 2015 12:43 am
I was lucky then... mine spent 1 month unused with a dying battery and the following month with no battery connected while the key was still taped in the antenna loop. It started first turn when I fitted a new battery.
James
'91 325i Sport
Danny-C
Mon Jun 08, 2015 10:16 pm
Hi guys, had the ews delete done and still have the same problems, any ideas plzzzz
