1984 318i steering rack
- hmuminovic
I've got a 1984 318i with no power steering. I want to keep it this way but wondering is there any racks out there which would give me better turning ratio?
						- hmuminovic
How difficult is it to get powersteering on my 318i then with a Z3 rack?
						- madmax1410
not difficult if you can source all the parts of a breaker! however the brackets for the m10 power steering pump maybe a little harder to come by unless there the same as the ones used on an m40 then your golden!hmuminovic wrote:How difficult is it to get powersteering on my 318i then with a Z3 rack?
you will need
power steering pump/brackets
pipes
rack
drive belt
maybe a different pulley for the crank also to drive the pump!
if fitting either an e36 e46 z3 rack ect.. i believe you need spacers for the bolts on the rack to subframe! also you will need extended pipes and e30 tie rods. there maybe more to do a bit of a search on the site and you should find more info!
- hmuminovic
Much appreciatedfor the info. I think that will be a nice summers weekend job
