yes mate im always about
new monster v8 no 4.0 here !!! Start up vid on page 28 :)
ross2009
kev where you been ?
ross2009
Done abit more today fitted the manifold properly
Fitted the dizzy plug with a new clamp
The dizzy plug still needs to be there as the dizzy also drives the oil pump from the cam
Also finished the heater pipes for the matrix
Had a mock up of the intercooler too it just about fits lol
Fuel system and boot install next up
ross2009
Put the lift pump for the swirl pot together in a standard cradle ( thanks mick for that )
This pump will fill a 2ltr swirl pot in about 40secs , I'm going to be running twin bosch 044 pumps which will empty that swirl pot in 1.6 mins so it's plenty and will never run dry
Just waiting for the swirl pot to turn up now
S38B38
Mindblowing
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
ross2009
Done abit of everything this week as work wasn't busy swirl pot has turned up and is now plumbed in
Just offering it up in the boot as I have to get filters on the end of these too
Had to machine my front brake bells out a little to fit over the 5 stud hub but not a problem, plus elongated the bolt holes a little as these bells were 5x114
So now back on to the rears as when I mocked these up before the brake shoes were showing from behind the disc
so I thought of a solution to this by machining the rear of the hub to bring the disc in further , but that was a no no as it would have only left 6 mm of meat to hold the rear together
So had another think I needed to bring the shoes and hand brake assembley forward, so why not make a spacer ?
So I did I needed about 8mm so I got some 8mm ali plate and started making some
This was the idea
So started chomping
Which turned out like this
And fitted like this
And with some longer bolts looked like this
So put it all together with the new hub
Hey presto
Just got to do the other side now , make caliper brackets and then on to the fronts
This was the idea
So started chomping
Hey presto
manse73
Ace work as usual Ross keep it going the warmer weather will soon be on us
Sebring grey motorsport convertible
ross2009
cheers kev ;)manse73 wrote:Ace work as usual Ross keep it going the warmer weather will soon be on us
ross2009
Well got the front wheel roughly where it needs to be, as the wheels were bigger I couldn't lower the car on the coilovers which left a rather hefty gap in the arch, so new springs had to be bought I went for 7" long 600lbs , bearing in mind the engine is roughly 500lbs
So that's 2" shorter than the standard gaz spring so it's gone from this
To this
Pretty much perfect by the time the full weight of the car is on the wheels
All my fuel line has now turned up so I can get that plumbed in and then start work on the front caliper brakets
It's getting there
To this
It's getting there
appletree
Good work on the spacer, very easy to make something like that look rough and ready bit yours looks good! Well done!
ross2009
Thanks dude, I'm an engineer by trade so things like that sort of come naturally lolappletree wrote:Good work on the spacer, very easy to make something like that look rough and ready bit yours looks good! Well done!
It's getting there slowly
ross2009
Just a few little updates
Caliper brackets are finished and calipers are now mounted
Fuel system in the boot is nearly finished , just need a return line back to the tank and bolt it down to the floor
New fuel lines are in and running from the front to the rear
Just need a few more bits for the engine now
ross2009
JF008
Always a good read
ross2009
thanks dude getting there slowlyJF008 wrote:Always a good read
glenn
- Engine Transplant Services
should that disc be on the offside ross ?
ross2009
no mate as it dosnt matter about the lines in the disc its the vanes inside that are directionalglenn wrote:should that disc be on the offside ross ?
glenn
ah yeh, i can see them now, perhaps i should take a better look before posting
ross2009
lol thas alright dont worry about itglenn wrote:ah yeh, i can see them now, perhaps i should take a better look before posting
ross2009
Well I finially got round to fitting the front arb if you can remember I've re mounted it to the front of the subframe and used a e36 m3 arb but as I moved the rack forward on the subframe due to the linkage hitting the starter motor , it now with weight on the front the arb now hits the rack so I've altered another crossmember but now keeping the standard rack mounts, as I now have a even smaller starter motor and more room for the linkage
I've just got to clean the lower arms up now and repaint them and fit new drop links
ross2009
ross2009
Not much room for rubber in there!
Demlotcrew
Stanced though
ross2009
No dan there isn't im going to have to space the wheel out more to give me more roomDanThe wrote:Not much room for rubber in there!
I think that's the only way I'm going to get decent rubber on it with out it catching
ross2009
ross_jsy
Looks incredible Ross.
Just a quick one, make sure you get a rubber fitting on that brake line connected to the suspension strut
ross2009
only temp at the mo mate . dont worry all in hand lolross_jsy wrote:Looks incredible Ross.
Looking great, though looks like one of the snails could do with a lick of paint to match t'other one...
craigieeb
Speedtouch wrote:Looking great, though looks like one of the snails could do with a lick of water to match t'other rusty one...
They all go this way
M50 Turbo!!!
I shall say no more
ross2009
It's just were one has been blasted after a rebuild, and the other has been out side in the elements lolSpeedtouch wrote:Looking great, though looks like one of the snails could do with a lick of paint to match t'other one...
They will both have blankets on that when I get round to it
