Hi I'm looking to put powersteerring in my e30 what do I need ?
Please help can't handle parking anymore
1987 318i m10 powersteering conversion
JF008
Try the technical help section
JF
JF
cool_ram_in
There´s still the support plate that bolts on the block, available from BMW. A few years ago it was very cheap. For the rack, pump and tubes i use a full steering setup from some regular e36. Forget z3 and M3 e36, the regular one is miles away from mechanical e30 and from power e30 rack. 3 and a 1/4 turn if i recall. (that´s exactly my setup ;) )
You may need to mod the adjuster plate for tensioning the steering pump belt, probably depends on what model pump you get...
For the install there´s tutorials here... just search for e36 steering swap.
Give us feedback then...
ps- Best upgrade for the money!!!
