Using Getrag 6 Speed - Which driveshaft to suit?
Z2TT
Post Wed Feb 04, 2015 11:24 am
Hi Guys.
I'm assuming this would apply to both S50's and M50's, I got an S50 but I'm asking in the M50 thread since I may got some more views, as I assume the engine would sit in the same general area.
I know with a ZF 5 Speed 328i or M3 Box, a 328i driveshaft is bolt-in and the correct length with no custom mods required.
How about if using a E36 M3 Getrag 6 Speed Manual, which model driveshaft will be a good fit?
Cheers.
Post Sat Feb 07, 2015 9:08 pm
you can use an e36 m52 prop but it needs to be shortened and balanced , i'm having this work done soon for £60 ...are you aware that you need to make some sort of custom brackets for the gear box mounting ...
i have pics of a decent design and a bosh it one lol
or this safe looking number available at £50 + post :eek:
jimbom30cab
Tech 1 freak
Post Sat Feb 07, 2015 9:13 pm
in the top 2 pics the gearbox crossmember is actually welded to the 2 brackets also.
The 2 supporting brackets are made from 3mm thick steel
It's strong
Post Sat Feb 07, 2015 9:19 pm
jimbom30cab wrote:in the top 2 pics the gearbox crossmember is actually welded to the 2 brackets also.
It's strong
do you own a tape measure :skip:
Acaciastrain360
Post Sat Feb 07, 2015 9:46 pm
I have a custom propshaft for getrag 6 speed I had on my m50... PM me if you're interested...
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
Acaciastrain360
Post Sat Feb 07, 2015 9:52 pm
magpie wrote:you can use an e36 m52 prop but it needs to be shortened and balanced , i'm having this work done soon for £60 ...are you aware that you need to make some sort of custom brackets for the gear box mounting ...
Don't forget E28 rubbers...
