Fan Blades Meltin????
REEDY
Post Thu Jan 26, 2006 6:52 pm
Hello people!!
Has any1 come across this?? It looks like my fan blades are melting into the radiator, then wedging themselves in the radiator housing?????
Stopping the blades from spinnin then overheated when stopped!!!
I need to sort it before monday otherwise no Ace Cafe :( ??
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Thu Jan 26, 2006 7:05 pm
Sounds to me that the water pump bearings have failed allowing excess play in the whole assembly causing blades to touch radiator.
Taylor.
REEDY
Post Thu Jan 26, 2006 7:19 pm
WaterPump has just been changed as well as
oil pump, Engine and gearbox mounts!
Viscous Coupling and the fan blade!
Also Engine has been out to change the gearbox shaft seal!
Any chance it could have been replaced in the wrong position??
