The Audi m/c however has 4 connections for brake pipes whereas the e30 one only has two. What are these additional connections for and am I ok to blank them off and just use two?
I'll obviously use one output from the front and one from the rear of the m/c so the front and rear brakes remain on different circuits but apart from that does it matter which ones I use?
And one other thing, as I am yet to remove my original m/c and reservoir: does anyone know the dimension between the holes on a standard e30 reservoir? The dimension is 90mm on the Audi one and I'm wondering if the e30 resevoir will fit straight on?
