New engine, same old problem
Cloggy Saint
Post Wed Feb 04, 2015 12:53 pm
If I need to stop and start the car a few times in succession when the engine is hot i get all kinds of trouble. Throttle response is terrible, the car judders and mis-fires and it's generally rough. I had exactly the same problem when the car was a 2.0 and was hoping that with a new engine, loom, ecu etc the problem would end up in the skip with the b20! What could be causing this?
BenHar
Post Wed Feb 04, 2015 1:02 pm
Did you reuse anything from the old engine?
Ben
Cloggy Saint
Post Wed Feb 04, 2015 1:04 pm
Nothing.
BenHar
Post Wed Feb 04, 2015 1:11 pm
The symptoms sound like leaking injectors.
Check the fuel rail pressure.
Ben
Cloggy Saint
Post Wed Feb 04, 2015 1:18 pm
The injectors were refurbed by injectortune before fitting but I'll check it out.
edit: How do I check it out? :)
BenHar
Post Wed Feb 04, 2015 1:57 pm
<Brianmoore> Get a £10 pressure gauge from ebay and connect it in line to monitor the pressure.</Brianmoore>
If the pressure drops rapidly after turning the engine off either the pressure regulator or injectors are leaking.
Ben
Cloggy Saint
Post Wed Feb 04, 2015 2:31 pm
But if this was the case wouldn't the problem be constant?
BenHar
Post Wed Feb 04, 2015 3:37 pm
If the injectors are leaking down after you stop then when you restart with the engine hot there will be extra fuel in the manifold making it run rich for a short time.
Ben
**BANNED**
Post Wed Feb 04, 2015 3:38 pm
Whilst fuel starvation is a good call,I'm wondering if the issue could be as simple as a corroded earth strap...
I would replace the engine/chassis earth strap and polish(with a wire brush!)the mounting on the chassis leg.
Bear in mind that the ECU functions by receiving odd voltage signals from several engine-mounted sensors,so a dodgy earth will confuse these.
Youth is wasted on the young.
Cloggy Saint
Post Wed Feb 04, 2015 3:39 pm
Ah, that makes sense, thanks.
