Hi all. Sought advice from you guys in the past, thanks. Would now appreciate advice on fixing a leak in o/s rear footwell on my 1988 320 cab. Car is off road until March and while taking out front pax seat I lifted rear carpet and saw bottom foam part of carpet was drenched, top of carpet is dry. The leak appears to be coming from an area that looks like it has a large plug, it was covered by some kind of sealing cover and when I pressed down on it, I could see the water being squeezed out. I have chipped away this cover to reveal mastic which I assume seals said large plug and I am assuming this has perished and needs replacing. Car hasn't been on road since October and I can only remember driving on Mway in torrential rain once for about an hour the month before. No leaks in roof. I haven't looked underneath properly yet due to my mobility, a small garage and the cold!
My question is, can you tell from photos if plug is just worn out, or does it look like a dodgy repair and is it something that could be far worse like rusty floor? Rest of floors all look ok but notice a small bit of what looks like surface rust leading from back area.
Apologies for going on so long!
