Has anyone fitted one of these kits?
I've just recieved my kit but the installation instructions are non existent. Can anyone give me any pointers as I hate electrics & don't want to fry owt.
Jamie
Right click remote locking.
Fitted several of them, and always found them reliable. Only criticism, if any, is that the range is too great. The fob will unlock the car from indoors, when the car is 25m away in its garage.
Wiring instructions are about half way down this thread: http://www.e30zone.net/modules.php?name ... rightclick
All the wires you need to connect to are behind the glovebox area.
jimbom30cab
- Tech 1 freak
Brian, is there any particular one you would recommend?
They're all the same unit - just with different styles of fob. The 670 is the one with BMW style keys.
Rhyse30
Brian, by 'the 670 is the one with BMW style keys' do you mean you can get these cut to fit an e30 lock?
Marneus
Thanks Brian, I'll have a go at this when the weather clears up. Would it be ok to pm you if I get stuck? It should be straight forwards but who knows....
You can specify them with a key blank that can be cut to fit your ignition switch.Rhyse30 wrote:Brian, by 'the 670 is the one with BMW style keys' do you mean you can get these cut to fit an e30 lock?
Rhyse30
Ah right ok. Is it HU49 or HU72?
HU50 is the E30 blank. HU58 is for later cars (E39, etc.).Rhyse30 wrote:Ah right ok. Is it HU49 or HU72?
