Things to replace once re-fitting intake manifold on m20b25
MPOWERCRAZY
Post Thu Jan 22, 2015 12:15 am
Hi,
I'm wondering what other parts need replacing besides the manifold gasket it self? Part numbers will be helpful to so i can get a price on here also!
Back Again From The Darkside Of Doing E36'S :mad:
Back With 2 E30 Projects :cool:
Post Thu Jan 22, 2015 12:28 am
It's manifold gaskets - there three of them. Throttle body gasket should be replaced (but is often reusable), the O rings on the spring loaded oil tube need replacing, and the injectors need new O rings if they've been removed.
If the injectors have been sent for reconditioning, they will normally be returned complete with new O rings.
There's also a gasket for the thermostat elbow, if that has been removed.
MPOWERCRAZY
Post Thu Jan 22, 2015 12:44 am
Brianmoooore wrote:It's manifold gaskets - there three of them. Throttle body gasket should be replaced (but is often reusable), the O rings on the spring loaded oil tube need replacing, and the injectors need new O rings if they've been removed.
Thanks, will most likely send the injectors of for reconditioning, seen a fellow zoner who does that on here, is it best to order all the gaskets etc from dealers? Also is it essential to remove the thermostat once taking the intake of?
BenHar
Post Thu Jan 22, 2015 1:42 pm
Rubber blanking bung for under the throttle body. 11611727176
Ben
Kedge
Post Thu Jan 22, 2015 4:39 pm
No, you shouldn't need to take it off to get the inlet manifold off. However, whilst in there with so much easy access it's a good time to change that as well, sods law a few months down the line it'll end up leaking.
Instagram - Kedge85
MPOWERCRAZY
Post Thu Jan 22, 2015 5:01 pm
I've already had it changed once i had my car in for some work
