Could I get prices on the below,
52108202407 - Assuming this i same as montana saffron yellow?
52108151597 - screws to fix luggage net
Need the gearshift parts as well
25111221864 - arm
25117507695 - bush goes into arm
25111222015 - bearing for shift arm
25111220600 - shift lever bearing
25117580281 - rod joint
25111222451 - lock ring
23411466134 - dowel pin
I Also require the little sponge piece which sits inside the rod joint. not on realoem.com?
Also have a sunroof issue unfortunately, its not opening, apparently a common issue?
54128206384 - Is this a repair kit for the issue?
also if available a tube of pu underseal the genuine bmw stuff,
Thanks!
E36 shifter linkage / sunroof repair Parts prices
Cotswoldbmw
Dear BMW9818.
Thank you for your enquiry, the price for the parts required will be £165.62.
All prices quoted are for Genuine BMW Parts and include a discount for enquiring on line, VAT and no postage charge to a mainland UK address. If you need a price brake down please let me have your email address. Part ending in 407 Is no longer available from BMW.
The sponge bit is not shown it may come with the joint! Some of the parts will have to come from Germany.
Under body sealant 51910427674 is this what you need?
Give us a call to place an order on 01242 588495 and please quote reference number 44890
Regards
Paul
Paul Webb
Parts Advisor
Cotswold Cheltenham
Main Telephone Number: 01242 257999
Fax Number: 01242 257150
E-mail: partscheltenham@cotswoldgroup.com
Website: www.cotswoldgroup.com
Regards
Paul
Paul Webb
Parts Advisor
Cotswold Cheltenham
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
bmw9818
Hi could you possibly requote just for the gear shifter parts,
do not require any sealant or anything numbers ending 407 or 597 or 384 sunroof kit
thanks will call and make payment.
and also an m3 boot badge for an e36 m3 R reg - individual price on this please
Cotswoldbmw
Hi quote has been changed and new total is £98.29. The badges need to be ordered to an M3 chassis number. let me have your email address so I can send the quote.
regards
Paul.
regards
Paul.
Cotswold BMW Parts
01242 335365
01242 335365
Cotswoldbmw
Hi I have sent the quote. Thanks.
regards
Paul.
regards
Paul.
Cotswold BMW Parts
01242 335365
01242 335365
