325i starter motor wiring
dje30
Sat Jan 10, 2015 9:04 pm
Can anyone tell me what each wire on the starter does/is for
Large ones I assume are battery and alternator
What are the other two?
dje30
Sat Jan 10, 2015 9:05 pm
Oh and car won't start with diagnostic plug start up
Grrrmachine
E30 Zone Wiki / Team Member
Sat Jan 10, 2015 9:43 pm
From the wiki:
Green/black goes to the unloader relays and provides a signal causing them to drop out when you are starting the car. The other smaller wire on the solenoid is the one that provides the power to pull the solenoid in.
http://www.e30zone.net/e30zonewiki/inde ... ter#Wiring
So do you have a non-start issue, or are you just curious?
dje30
Sat Jan 10, 2015 10:00 pm
It won't start yes - won't crank
Have power at the ignition barrel
At the connection in the glove box
At the c101 both side
The green and black wire has 12v switched live
kam-325i
Sat Jan 10, 2015 10:10 pm
car wont start with diagnostic plug start-up, that is only for turning the engine over...
dje30
Sat Jan 10, 2015 10:21 pm
It won't spin over doing the diagnostic plug way
Grrrmachine
Sun Jan 11, 2015 8:10 am
WillNZ wrote:If the starter does not swing over, the starter is faulty.
Or the battery is flat :D
ethrty
Mon Jan 12, 2015 5:09 am
have also come across this using early starter motor in a facelift car, Im going to assume that you are just experiencing a faulty one, and this doesnt follow on from an earlier change exercise?
dje30
Tue Jan 13, 2015 8:17 pm
99% sure the starter is dead :-(
I have a spare does anyone know how to test it on the bench so I know if it's good or not?
dje30
Tue Jan 13, 2015 8:27 pm
Sorry and the difference between facelift and pre facelift
Tue Jan 13, 2015 8:45 pm
dje30 wrote:99% sure the starter is dead :-(
Connect battery negative to the motor case. Connect battery positive to the outer large terminal on the solenoid. Connect the larger of the smaller terminals (post facelit) or only smaller terminal (pre facelift) to battery positive, and the pinion should move over and spin.
Doesn't check the torque of the motor, of course, just that it runs.
Pre facelift motors are often physically larger, and don't have the fourth terminal. This can be overcome, if need be, by changing the small ring terminal on the green/black wire that goes to the fourth terminal for a much larger one, and connecting it to the inner large terminal on the solenoid.
dje30
Tue Jan 13, 2015 10:18 pm
when testing my one on the bench the gear comes out but wont spin?
Tue Jan 13, 2015 10:39 pm
Short across the two large terminals on the solenoid with a screwdriver blade, with the battery still connected.
dje30
Tue Jan 13, 2015 10:42 pm
I'll try it tomorrow as I'm home now
dje30
Tue Jan 13, 2015 10:43 pm
Thanks for your help I'm very grateful
