Brake pedal transfer rod on bulkhead factory M30 E30
scoobydo
Post Fri Jan 09, 2015 9:55 am
Has anyone got any pictures of a stripped right hand drive car around the dashboard area. Have moved my engine back 30mm on my 333i and looking to create some room to keep the gooseneck water pipe that is on the back of the e34 heads. Need to know how much clearance there is between bulkhead and bar and also if there are any brackets around this area.
Thanks in advance
