Drove it as a daily for 12 months, has been off the road for a couple of years for a restoration.
Couple of pics of how it looked
now im out there nightly or as often as I can chipping at it little by little.
I'm spraying down ppg 2K epoxy and prima and getting it sprayed in Audi's Brilliant Red at work.
why does the green look good?hand rolled fender
and finally got a coat of primer on
started on some rust, a spot had rusted through the rear vallance on the RHR, so I cut it out and found behind it there was more rust.. So I cut a larger section out to repair the box section where the battery sits. BMW Brainfart.
cut a section from a spare fender to get the ridge line and bent to shape.
sprayed down epoxy and epoxy in the cut out cavity to prevent future corrosion, also sprayed both sides of the patch panel prior to welding.
I have to cut out the LHR vallace corner next and replace it. Found it all caved in and leveled with bog.. YUCK.
