new monster v8 no 4.0 here !!! Start up vid on page 28 :)
Amazing build! You'll be happy to know I recently got my hands on the intake you made for your m20 and will be going on my 500+ whp build for next season. Might start a thread here on my drift car but figured I'd let you know! Had to find the guy who made it.
josh ???FLG wrote:Amazing build! You'll be happy to know I recently got my hands on the intake you made for your m20 and will be going on my 500+ whp build for next season. Might start a thread here on my drift car but figured I'd let you know! Had to find the guy who made it.
Haha I might pm you when I get it in hand, unless it's quite obvious I was wondering how the tps senor was mounted. This is the car it will be going in btw.
http://www.r3vlimited.com/board/showthread.php?t=295277
Dont want to derail your build thread. Looking forward to seeing more though!
Got a few more bits for the rear and 5 stud conversion
Had a little test fit of the new wheels although there not actually bolted on or anything
The hub and disc pics before , I didn't realise that they were the wrong ones they are z3m ones not z3 ones but now I've bought brand new ones from the dealers
New bbs stainless valves
Small update I've got the rear discs on for mock up , the hubs need to be machined to let the disc go bk further for the hand brake shoes to be covered, as the hubs stick out to far, anyone that knows me knows I don't do things the standard way
Here's the discs behind the wheels there 300mm z4 discs on a z3 hub and will be running Porsche boxster rear Brembo 4pots
As you can see the shoes don't quite go under the disc hence the machining
As for the fronts there going to be a sleeved stub axle with e36 hubs
Blasted and cleaned up the front calipers they are staying red so they will be painted this week
Also took the xyz logo off too
And just some odd more bits that I've got new coil packs for the efi swap
And my new wheel bolts for the hartges
New front strut top mounts too, as mine are poo poo
Will have more updates by end of the week as I have some goodies coming from the usa , rear calipers will be here and the fronts should be painted
Looking great, they're some sexy looking wheels, bet you can't wait to see it sat down on them with the brakes behind them. Will the rear arche need rolling much then?
appletree wrote:Looking great, they're some sexy looking wheels, bet you can't wait to see it sat down on them with the brakes behind them. Will the rear arche need rolling much then?
Cheers dude they do look awesome
I can't wait either mate just gotta finish off the 5stud and brakes then I can get the wheels together
Tyres and get it back on the ground
Not sure about the arches yet I shall see more when I get the hubs on
Front hubs are tested fitted just got to get some new hub nuts
As the brakes and wheels are nearly sorted I thought I'd turn on to the fueling of this monster
This thing is gonna need some fuel supply,I've worked it out at wot on boost its gonna need at least 520lph
I wanted to stick with an Intank pump but for that flow it's not going to happen so it's going to have to be a twin pump system, I've decided to go swirl pot and twin pumps in the boot , now I know it's not going to be no track car to have the need for a swirl pot but there isn't no were to put the pumps inline underneath with out welding outlets on the tank
So it's the easiest solution with a low pressure lifter pump in the tank
A few bits and pieces
To feed this bad boy
More goodies to come next week
ha ha yes it will its actually lower than the normal manifold carb and filter set up nowjmc330i wrote:Will that even fit under the bonnet??ross2009 wrote:To feed this bad boy
I can't wait to see this finished![]()
so will be fine the engine site quite low as it is
believe me i cant wait either
- Tech 1 freak
Wow !
ha ha yeah it sits outside now with a cover unfortunatly , i will be getting turbo blankets for them so they dont look as bad
just got to get it all bolted down now and get all the fuel rails and lines plumbed in
looks better than that old carb dont it
