maf convertion
gafta
Post Sun Nov 09, 2014 10:54 pm
has anyone here done a afm delete and replaced with a maf meter instead? im seeing miller performance do this but there prices are very steep in my opinion.
jimbom30cab
Tech 1 freak
Post Sun Nov 09, 2014 11:38 pm
Yes, only do it if you are prepared to spend £500 or more on a proper mapping session. The Millar chips are not ideal.
My advice, save you ££ and go on holiday instead.
Kedge
Post Wed Dec 17, 2014 4:45 pm
You didn't rate it then Jim?
Instagram - Kedge85
jimbom30cab
Tech 1 freak
Post Wed Dec 17, 2014 5:26 pm
Well, the off the shelf millar maf and chip has a map which is quite lean. It would be good i think but needs proper mapping ideally. I tried a few different chips and actually the Millar is the best one out there.
Not to worry, i'll get it off to Gunni in the new year
Cheers :)
Kedge
Post Wed Dec 17, 2014 8:39 pm
Got ya. I've not tried mine yet, going to stick with the AFM until I take mine for a proper mapping session and will try and get a map done for both.
Instagram - Kedge85
