hartge centre caps?
shanehaward
can you still buy hartge centre caps new, i want to get my wheels referbed in the new year but have no centre caps. I will probably sell the wheels after to part fund an engine swap, have 5 in total with 1 which is brand new and never even had a tyre put on the thing but no caps
shane
shane
Do not bother refurbing them or buying caps. Sell them as they are and sell the single new one separately.
This will give you the best net return and the least hassle.
HartgeH27
There is a unbeknown to Back Alley Pete's sources of Hartge centre caps. PM me if you are interested.
Cheers,
Iain
Cheers,
Iain
Indeed, the caps are readily available from Hartge for Ca 100 euros a set .
http://www.hartge.de/e/bmw_raeder_4323ac.html
But if the OP wants maximum return for least hassle, let the caps and refurb dramas be the next persons problem.
shanehaward
thanks pete and hartge, im in no rush at this side of the new year, unless sombody offers me some monies but good to know theyre still available at a reasonable price, the wheels are in good condition but have been painted black so will put buyers off i think, the spare is still original though
what sort of money are they worth as is?(black, good proxes and no caps)
or refurbed with same tyres + caps?
j2b
cheap to me lol.
john
john
89 more door 6 pot
- E30 Zone Meets/Events Team
Pm me a price on tje wheels.
Need any centre caps rav?
j2b
DanThe wrote:Need any centre caps rav?
89 more door 6 pot
LOL, I have a few new sets left Dan...DanThe wrote:Need any centre caps rav?
MattTheHat325
I need 4 centre caps for 19" design D's, anyone know if they are specific or can the more common 17" caps fit?
It's more the c/b size. iirc the caps for 17" onwards are the same in diameter
17's are a bit bigger and the fitting lugs are deeper
MattTheHat325
Think my 19's are 82mm cb with spigot rings, is that the same as 17's? Are they still available? Be handy to try one in there just to see
Normally 72mm c/b.
MattTheHat325
Mine are definitely over 80mm, when I bought them two of them were fitted with a steel spacer which reduced the cb to 72.6 and the other two had normal plastic spigots in. I took the spacers off as the offset was too low and put spigot rings in. I've never been able to find much info on them and the only car I've seen with them fitted was an e31. If the caps are specific to the 19" I think my chances are slim
Matt try the link above. They might have some in stock.
MattTheHat325
The e30 is the only one on hartge's site which still has the big flat caps showing, all the other models are showing the little modern caps for the newer halfords wheels
Would help if I knew what they were originally fitted to/made for!
Are yours the ones with locks?
MattTheHat325
Push on plastic. I doubt you'll find a set.
Have you tried Ed38 or Wheel-Whores sites?
MattTheHat325
So will they be specific to the 19 or will 17's fit rav? I haven't to be honest, wheel whores might be worth a look!
