valve stem oil seals ?
elring £8.99 delivered
http://www.ebay.co.uk/itm/VALVE-SEAL-SE ... 2c73b70d22
Victor Reinze £41 delivered
http://www.ebay.co.uk/itm/Valve-Stem-Se ... 19f5f13e43
or an un named maker ? £35 delivered .
http://www.ebay.co.uk/itm/BMW-E36-E46-E ... 4610eeb055
elring were recommended along with the V,Reinze head gaskets , has anyone used elring stem seals ??
elring or victor reinze ?
+ a yard full of scrap turds
Elring are a premium brand and comparable in quality to Victor Reinze. I have used their products for years and never had an issue. The much cheapness is an added bonus !
order placedpacerpete wrote:Elring are a premium brand and comparable in quality to Victor Reinze. I have used their products for years and never had an issue. The much cheapness is an added bonus !
elringklinger.
I have made tooling for these guy`s and their standards are well up there.
Mainly it was a nice piece of kit to form the metal rings around the bores of head gaskets. If you notice that some are concave and this takes a cool bit of engineering, and I have used gaskets from them since with no problems at all.
No discounts though.
anyone got any links to quality crank shells or piston ring sets for m54b30 ?
You'll want Karl Schmidt or KS are good. Theres more that i'm forgetting NE npr europe i've used on my e46 B3s go to your local machine shop they'll be the cheapest by far. The bearings for that crank will be the same as an M20b25 45mm big ends and 60mm mains. BMW don't really change these things unless they have to.
nice oneSimon13 wrote:You'll want Karl Schmidt or KS are good. Theres more that i'm forgetting NE npr europe i've used on my e46 B3s go to your local machine shop they'll be the cheapest by far. The bearings for that crank will be the same as an M20b25 45mm big ends and 60mm mains. BMW don't really change these things unless they have to.
i had these rings in my watch list
http://www.ebay.co.uk/itm/270933101323? ... EBIDX%3AIT
i told you a slight porky, the main end shells fit the S50, M54, M52 inc. TU, M50 vanos, M44 and M43 engines according to real OEM
as for the big ends also fit M40, M42,M43,M44, M20 B25s , M50, M52, M54 and S50 engines
So theres big cross over but i wasn't quite right!
when i picked my con rod bolts up from BMW he confirmed the big ends were the same part number as [example] G-reg 325i so the ones in this link should be fine yeah ?
http://www.ebay.co.uk/itm/BMW-E28-E30-E ... 3f22904ace
