Standard BMW electric pins?
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Dec 02, 2014 11:40 am
All the plugs in the engine bay (headlights, foglights, washer pump etc) use the same sort of round plugs to connect up to their respective parts. But does anyone know the part number for the pins they plug in to?
I've got a heated washer loom that piggybacks off the washer motor, so it's got both male and female plugs, but the male side (pins) have gone AWOL and I'd like to order replacements rather than bodge it on.
Post Tue Dec 02, 2014 1:06 pm
There are two types, straight and right angled, but you can buy new pins with wire tails from the stealers.
I just cut them out of E36's or E34's :D
Grrrmachine
Post Tue Dec 02, 2014 1:19 pm
It's not the plugs I need Dan, it's the pins. The only source I can find would be the little headlight loom that feeds the front parking lights:
Post Tue Dec 02, 2014 1:55 pm
Yes I realise that, I was thinking of this type of thing - http://www.ebay.com/itm/BMW-1984-1999-E ... 566cbede45
I take it you need the male pins?
Post Tue Dec 02, 2014 1:56 pm
ahh, just read your post properly :mad: :mad:
Post Tue Dec 02, 2014 1:58 pm
Post Tue Dec 02, 2014 2:01 pm
Grrrmachine
Post Tue Dec 02, 2014 2:25 pm
Yes! Them's the buggers! Cheers Dan.
Nearly 5 quid EACH though 8O If only I COULD just lop 'em off an E34...
HairyScreech
Post Tue Dec 02, 2014 3:25 pm
Get plugs from a scrapy and crack the casings open to remove the pins intact?
Grrrmachine
Post Tue Dec 02, 2014 3:44 pm
Trouble is, most of the things with pins are the solid objects: waterpumps, headlight bulb holders etc. You end up buying the whole unit for $$$ just to salvage a few manky pins.
Hopefully these are the right size:
http://mikrokoszalin.pl/konektor-k115-c ... 40394.html
Post Tue Dec 02, 2014 7:55 pm
Uninsulated and wont locate into the plug housing.
The male pins are used on E36 elec fan plugs, cant think what else atm
Post Sun Dec 07, 2014 9:57 pm
I have a spare repair kit, BMW part number 1 382 248, that contains a number of these pins/connectors and lengths of black cable.
It was purchased for a BMW E34, long since gone, so is available for a reasonable offer. winkeye
