Bolt supply?
HairyScreech
Post Mon Dec 01, 2014 1:25 pm
I have just been trying to get some M12x1.5 10.9 grade bolts and can't seem to find any for love nor money.
Anyone know a source for some? I need some slightly longer ones for the calliper brackets so they have to be 10.9
40mm ideally but happy to cut some down.
It seems everywhere only has 1.75mm pitch or 1.25mm pitch and the E30 calliper bolts are 1.5mm pitch.
Post Mon Dec 01, 2014 1:29 pm
Loads on ebay, I use cap screws from a local supplier
HairyScreech
Post Mon Dec 01, 2014 1:39 pm
I tried Egay. Maybe I somehow fudged the search, couldn't find 10.9s on there.
Edit - bugger it, gone for 12.9 cap heads for now, will hunt down the correct M12x1.5 10.9 hex head bolts later.
What do you torque them to Dan?
Post Mon Dec 01, 2014 3:19 pm
FT :)
HairyScreech
Post Mon Dec 01, 2014 4:37 pm
8O Animal.
winkeye
Post Mon Dec 01, 2014 5:16 pm
With a 3/8 ratchet and experienced hand control/feel its not going to kill any threadsImage :)
maxfield
Post Mon Dec 01, 2014 8:51 pm
DanThe wrote:With a 3/8 ratchet and experienced hand control/feel its not going to kill any threadsImage :)
Or 2 ratatats on the buzz gun I'd you're a fitter :)
hennared323i
Post Mon Dec 01, 2014 9:59 pm
Do not over torque 12.9's
Different application I know but we replaced some 1 1/2" WW 10.9's with 12.9's and torqued them up to the same values....when the squeeze came on the bolt heads started firing off like bullets.
12.9's have a smaller plastic limit than 10.9's so less tolerant of over stressing
Post Mon Dec 01, 2014 10:24 pm
Indeed, the higher the number the more brittle the bolt is, what was the application out of interest?
hennared323i
Post Tue Dec 02, 2014 8:53 am
Holding a tunnel boring machine trailing shield in a fixed position.
When the driver got the machine geometricaly screwed up the friction generated by the lining binding on the inside of the shield and the ground binding on the outside was enough to split a few welds and pop a few bolt heads off.
Interesting times
Post Tue Dec 02, 2014 8:59 am
Cool, sounds like the 12.9 bolts would be much happier holding the brake caliper on an E30 :D
hennared323i
Post Tue Dec 02, 2014 10:00 am
Pic of cracked gusset and non sheared bolt heads (good side):
Pic of remedials after failure - big bit of steel and much welding:
hennared323i
Post Tue Dec 02, 2014 10:01 am
DanThe wrote:Cool, sounds like the 12.9 bolts would be much happier holding the brake caliper on an E30 :D
I expect they would :D
HairyScreech
Post Tue Dec 02, 2014 10:12 am
So quick check says 110-125Nm for a 12.9 M12.
(= 80-90lbft)
hennared323i
Post Tue Dec 02, 2014 10:13 am
HairyScreech wrote:I have just been trying to get some M12x1.5 10.9 grade bolts and can't seem to find any for love nor money.
These any good?
http://www.margnor-online.co.uk/167m12x1-5px40.html
HairyScreech
Post Tue Dec 02, 2014 10:16 am
:clap: That looks like the buggers.
Will have to save that link and put some on order.
Post Tue Dec 02, 2014 1:03 pm
No shoulder on that, which will weaken it to a degree if your being fussy. Id rather use a 12.9 with a shoulder, helps centre the bracket/caliper too which is why you find lots of automotive bolts have non standard shoulder lengths/diameters
hennared323i
Post Tue Dec 02, 2014 1:50 pm
http://www.margnor-online.co.uk/168md12x50.html
These then and buzz 10mm off the thread
Post Tue Dec 02, 2014 2:02 pm
HairyScreech
Post Tue Dec 02, 2014 3:21 pm
I don't think the bolts I took out were shouldered (or shanked if your like) will check when I fit the callipers.
Your right the shear strength is increased by shank bolts but only in the shanked section. Tensile strength is purely a smallest cross section thing so does not change.
For the 10.9 your looking at 90-110Nm.
suedenim
Post Wed Dec 03, 2014 1:24 am
Used to order from this company for architectural metalwork applications. Plenty of tech data on their site too.
http://www.vjtechnology.com/
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
mikelat
Post Sun Dec 07, 2014 8:17 pm
I get all my special bolts/nuts through aircraft supply outlets as they have lots of high spec stuff and at reasonable prices.
1990 325i Coupe Gletscherblau_Metallic
