Sams' small restoration............
Awesome.
Although is always a calculation, what flywheel power/torque did it make?
pony
- I have been misbehaving and am sorry !
Didn't think new spark plugs could make 20bhp difference ?
Marneus
Insane amount of power.... Must be fun
M3SAM
Pony my car had the original plugs from the factory that had done 60K. Combustion engines require Fuel and Oxygen to produce combustion what ignites the mixture? Spark plugs!
Forced induction cars require a fiercer spark because of the increased air volume/pressure and fuel volume. This is why the plugs were uprated and recommended by Andy @ Storm Developments the guy has a Doctorate of motor design and engineering you can always ask him.
These plugs are used on forced induction cars that require singular high intensity spark. They are Race plugs that can sustain higher temperatures and harder work cycle. More fuel burnt during combustion results in more power. Why do most race cars run two spark plugs per cylinder?
pony
M3SAM wrote:Pony my car had the original plugs from the factory that had done 60K. Combustion engines require Fuel and Oxygen to produce combustion what ignites the mixture? Spark plugs!
Ok thanks very much for explanation
I didn't even know race cars have 2 spark plugs.
Presumably to ignite more of the fuel / air mixture quick, reduce unburnt fuel and by igniting quicker maybe increase rpm ?
I didn't know Supercharged engines require fiercer spRk either till u explained it
So how much bhp increase does new plugs give on standard M20B25 typically
Kos
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
bmandy68
Very nice indeed great work well done super
ajay
Santa pod yesterday, this was the second of three runs, (with Sam a virgin down the strip) 12.6 seconds crossing the line at 116mph!
http://s1050.photobucket.com/user/ajspa ... 0.mp4.html
maxfield
Car of the show for me, looks like it's built properly!
I reckon it would be a 12 second car with the right start.
LondonTom
With all that power, if traction could be sorted (unlikely in an e30 and doubt the track was that well prepared) it should run low 11's.maxfield wrote:Car of the show for me, looks like it's built properly!
Get some sticky hosier's ordered Sam
Kos
track was quite well prepped and lots of rubber to hook up to but you'll need sticky tyres. Road tyres don't like the surface at pod
this car will easily go into the 12's
IG Pukar.Designs
IG Pukar.Designs
M3SAM
Time to start stripping the beast down for winter........
JOBS TO DO........
Steam clean underside and wheel arches
3 Way adjustable remote canister rear coil-overs
MK 60 Abs with DSC a la CSL spec (Dr Demlot technology)
New fan and controller
Power steering cooler
Electric power steering pump conversion
Bigger oil cooler
Front inner arches modified
Syvecs ECU with traction and launch control
Wideband lambda sensors
Radiator to be sealed off and new temperature sensor boss fitted
Carbon under tray with brake ducts
Uprated half shafts
ECU monitoring display
Grey seat belts
Floor over mats if they get sorted
New door glass both sides
Remap.........
MORE POWER!
All followed by empty pockets and overdrafts............
JOBS TO DO........
Bigger oil cooler
Uprated half shafts
Grey seat belts
Remap.........
MORE POWER!
Kos
That'll be sorted over weekend
IG Pukar.Designs
IG Pukar.Designs
maxfield
Is he a magician?Kos wrote:That'll be sorted over weekend
M3SAM
I've been beavering away..........
JOBS TO DO........
Steam clean underside and wheel arches (NEXT WEEK)
3 Way adjustable remote canister rear coil-overs (IN PROGRESS)
MK 60 Abs with DSC a la CSL spec (Dr Demlot technology) (IN PROGRESS)
Power steering cooler (NOT REQUIRED)
Electric power steering pump conversion (COMPLETED)
Bigger oil cooler
Radiator to be sealed off and new temperature sensor boss fitted (IN PROGRESS)
Uprated half shafts (IN PROGRESS)
Grey seat belts
Floor over mats if they get sorted (ORDERED)
Remap.........
MORE POWER!
JOBS TO DO........
Bigger oil cooler
Grey seat belts
Remap.........
MORE POWER!
Kos
Get a motec on there and let Fraser map it
IG Pukar.Designs
IG Pukar.Designs
M3SAM
Only if you pay for it!
Anyway it doesn't work with the DSC setup!
Fastroad
This car has come along way Sam, what was your last power output and what you aiming to reach?
M3SAM
UPDATE ENNIT
JOBS TO DO........
Bigger oil cooler
Grey seat belts
Floor over mats if they get sorted (FITTED)
New Fuelabs fuel filter (FITTED)
Remap.........
MORE POWER!
JOBS TO DO........
Bigger oil cooler
Grey seat belts
Remap.........
MORE POWER!
Demlotcrew
M3SAM
HALF SHAFTS HAVE BEEN DISPATCHED!
Does that mean you've broken some more Sam?
ajay
Kos
IG Pukar.Designs
IG Pukar.Designs
jimbom30cab
- Tech 1 freak
Any chance of a few photos of the article on the Facebook page please?
M3SAM
JF008
I read the article earlier, shiiiit man nice car
The bit about cutting a car in half reminded me of this thread I haven't looked at for months! I'm glad things worked out for you.
JF
JF
M3SAM
Coming out of hibernation soon I hear G1DTM has got some competition from McEvoy and the yank mongrel...........
Let the fun and games begin.............
Doobit
Loved this thread...but I guess it wasn't about the end result! What's next?
UmarK
Sorry about bringing this back from the dead, but what a fantastic example of how to modify an M3. I bet this would eat a few of those big power cossies out there.
What brake did servo did you end up using as the ESS inlet manifold looks to be a different size to the normal S54 one.
