Rear Screen Demister Not Working - Help
no1_jazz
Sat Nov 29, 2014 8:33 pm
Evening Zoners,
As with the weather getting worse and winter settling in. I guess it’s time to get this silly little issue resolved. The issue is that my rear screen demisters are not all working.
The bottom three lines of the screen seem to work and clear the screen however from there to the top of the screen it stays the same and not clear away when the demister switch is on.
What is the best way to resolve this?
All help is as always much appreciated.
Jazz
Jesus325iTouring
Frog freak !
Frog freak !
Sat Nov 29, 2014 9:19 pm
Sorry Jazz, my only help :D
polsta
Sat Nov 29, 2014 9:26 pm
Probably the lines have breaks in them, you need to repair them possibly ?
http://www.halfords.com/motoring/garage ... ter-repair
no1_jazz
Sat Nov 29, 2014 9:48 pm
Jesus325iTouring wrote:Image
lol I have been doing this far to long now fella ... its time...
:mad:
no1_jazz
Sat Nov 29, 2014 9:52 pm
polsta wrote:Probably the lines have breaks in them, you need to repair them possibly ?
Thanks Polsta,
I presume there must be some breaks in the lines I shall look into this. Failing this i'd guess it would be the case of biting the bullet and going to the dealers right?
Sat Nov 29, 2014 10:26 pm
it's easy to change the rear screen for a known working one from a local breaker .
no1_jazz
Sat Nov 29, 2014 10:38 pm
magpie wrote:it's easy to change the rear screen for a known working one from a local breaker .
Hi Mick hope your well.
The only problem here in the good ole east London is that all the good breakers have seemed to close down and or no longer stock parts for these old turds.
I am guessing id have to bite the bullet and go to the dealers. :?
andyp
True Old Skooler
Sat Nov 29, 2014 10:58 pm
ive sold 4 in the last month
Cloggy Saint
Sun Nov 30, 2014 12:01 am
Be glad you don't have a touring. Not an easy DIY fix and big money to replace.
Sun Nov 30, 2014 12:10 am
do a wanted add and collect it ..i'm sure you'll find someone within 30 miles that has one ...after all most e30's have them .
no1_jazz
Sun Nov 30, 2014 6:36 pm
magpie wrote:do a wanted add and collect it ..i'm sure you'll find someone within 30 miles that has one ...after all most e30's have them .
I think ill do just that.
Thanks Guys.
J
zd3bx
Sun Nov 30, 2014 7:09 pm
That windscreen stripe repair thing from Halfords is rubbish or at least I found it useless. You will just make a big mess instead of sorting the problem.
Replacing the rear screen is not a big deal, because it's not bonded like on modern cars - you can take it out in 5-10 mins with the right tools.
See this post in my project thread > http://www.e30zone.net/modules.php?name ... 20#2594620
pony
Sun Nov 30, 2014 8:23 pm
Also doesn't work on mine
pony
Sun Nov 30, 2014 8:24 pm
Will replacing original windscreen devalue the vehicle :-) ?
**BANNED**
Sun Nov 30, 2014 8:34 pm
pony wrote:Will replacing original windscreen devalue the vehicle :-) ?
Will replacing the original oil filter devalue the vehicle? :roll:
polsta
Sun Nov 30, 2014 8:48 pm
zd3bx wrote:That windscreen stripe repair thing from Halfords is rubbish or at least I found it useless. You will just make a big mess instead of sorting the problem.
I've never tried , but there are other similar products , ultimately it will depend on how much is needed/how many breaks ? IF you could find it and was 1 or 2 tiny breaks and you were careful it may be good or say if 1 tiny break in a non central area
But if the other option is swapping the screen .. Then theres nothing to loose and its worth a go
Maybe get in the car with a big magnifying glass and start from bottom and work way up looking closely ?
pony
Sun Nov 30, 2014 9:53 pm
Please act with the maturity of your grand age !
**BANNED**
Mon Dec 01, 2014 5:28 am
Look what's talking! :mad:
Kos
Mon Dec 01, 2014 10:31 am
daimlerman wrote:
pony wrote:
daimlerman wrote: Will replacing the original oil filter devalue the vehicle? :roll:
Seriously :roll:
www.pukardesigns.com
IG Pukar.Designs
no1_jazz
Mon Dec 01, 2014 11:08 am
Thanks Stephan. I had a quick brows through the halfords site and it seems the reviews were very negative. According to the reviews most people had bad experiences with this stuff.
Ill stay well clear. Ill just hunt a good used one and be done with this.
Mon Dec 01, 2014 2:24 pm
There is two pack epoxy electrically conductive silver 'paint' available, that will do the job if used as per instructions, but you won't find it in places like Halfords.
If you go down this route, make sure you get the electrically conductive version, not the heat conductive similar alternative.
Jona1971
Mon Dec 01, 2014 5:49 pm
I have 2 small breaks and need this too. Any ideas where to get this from Brian?
Thanks,
Moredoor autos with small engines are cool - but my new m20b25 is awesome!
Mon Dec 01, 2014 6:15 pm
blazed
Mon Dec 01, 2014 6:57 pm
http://www.ebay.co.uk/itm/Arctic-Silver ... 1179086715
I think this is very much the same and a good brand.
Mon Dec 01, 2014 11:08 pm
blazed wrote:http://www.ebay.co.uk/itm/Arctic-Silver ... 1179086715
You won't get very good results with the above!
brianmoooore wrote:If you go down this route, make sure you get the electrically conductive version, not the heat conductive similar alternative
