Drivers Sport Seat - Help and Guidance Required
Tabbi
Thu Nov 27, 2014 10:44 pm
Hi Guys, i need some help with my drivers seat which is loose on the back section at the bottom left. It is further back and loose compared to the right side.
It isnt a enjoyable experience as my body is angled when driving!!
Any ideas....?
Cloggy Saint
Thu Nov 27, 2014 10:46 pm
Either the bracket that holds the back rest to the base has broken (not unheard of) or the screw that secures it in place has come loose. Take the seat back cover off and all will be revealed.
Grrrmachine
E30 Zone Wiki / Team Member
Thu Nov 27, 2014 10:47 pm
Taken from the Wiki:
"Remove the panel from the rear of the seat by undoing the two screws at the base. Locate the large cross-head screw near the bottom of each side of the frame upright section. If the seat back is wobbly it is almost certain that these screws have worked loose.
Use a large philips screwdriver which is a good fit in the head of the screw to tighten these right up ( a small screwdriver won't do it and they'll work loose again.) Then refit the rear panel. "
However, if the frame has been left loose for too long, there is a chance something will have snapped and you'll need a welder to fix it. Hopefully it's just that screw though.
Tabbi
Thu Nov 27, 2014 10:53 pm
Ok i will investigate that at the weekend.
Many thanks mate, much appreciated.
Tabbi
Sun Dec 07, 2014 8:13 pm
Hi guys, had a look at the seat earlier and the L shaped bracket has snapped. I will get this welded but I now have an issue with the tilt mechanism. It doesn't always lock in place and will recline aswell as drop seat height!!
Not ideal when when driving. Any ideas....?
Thanks.
BHadley
Sun Dec 07, 2014 8:35 pm
The two are connected.....
My passenger seat was the same once the bracket was welded on and everything refitted it was fine.
The seat is out of alignment as the bracket is currently broken so has movement to slip out of tilt..
Tabbi
Sun Dec 07, 2014 10:18 pm
Ok, so I will get the bracket welded, re-assemble and see how it goes.
Thanks bud.
Tabbi
Wed Dec 10, 2014 1:34 pm
Well took the back off the base and took the whole base to have the bracket welded.
Came home, re-assembled and put back in the car. As soon as i sat in the seat and lent back....... clunk!!
There she goes again!
Ahhhhh..... the joys.... :D
BHadley
Wed Dec 10, 2014 4:49 pm
Oh! Has the other bracket broken or the rachet on the seat given up the ghost ?
Tabbi
Wed Dec 10, 2014 5:23 pm
The same bracket i had welded snapped again......
BHadley
Wed Dec 10, 2014 5:32 pm
That's annoying.
May be better to make up a new one and turn up the voltage on the welder?
Tabbi
Wed Dec 10, 2014 5:49 pm
Unfortunately i dont have a welder and took it to a local 'garage' to have it done. I think i will take it back and get them to do it properly this time!
mcspike
Thu Dec 11, 2014 5:07 pm
It is very easy to take off the tilt mechanisms from another seat (does not need to be sport) and fit them onto the sport seat.
Ryan
Tabbi
Thu Dec 11, 2014 8:09 pm
Ok, well what i think i will do first is have the bracket welded and then see how i get on. If i still have issues with my mechanism then i will look into replacing them on both sides.
Thankyou for your advice.
