touring in the scrap yard
lhd220turbo
Post Tue Nov 25, 2014 10:00 am
There's a white touring 320 in my local scrap yard, is there any bits worth taking off that are hard to get hold off or worth a few quid?
shame for it to see the crusher if I can get some bits off it
BenHar
Post Tue Nov 25, 2014 10:47 am
If the tailgate is rust free it's worth a few bob.
Ben
Motorhole
Post Tue Nov 25, 2014 11:35 am
Always people looking for 51mm front struts and rear disc trailing arms!
Also the anti-roll bars (front and rear) could be considered an upgrade for most non-sport E30s.
steve_k
Post Tue Nov 25, 2014 11:47 am
why not see if you can get the whole car?
then strip it & sell off the part's, makes more sense to me.
appletree
Post Tue Nov 25, 2014 12:34 pm
Did the 320 tourings get the bigger rear claipers too or are they on drums?
andyp
True Old Skooler
Post Tue Nov 25, 2014 12:36 pm
disc
HairyScreech
Post Tue Nov 25, 2014 12:40 pm
Yep, All tourings have the larger rear callipers and 325 fronts.
However the fist part of any e36 calliper is the same and goes on with E30 brackets.
lhd220turbo
Post Tue Nov 25, 2014 8:46 pm
thanks, i'll have a closer look, someone has already had the windscreen out of it. the o/s rear wheel is not facing the right way, so its not even rolling otherwise i would have considered the whole car.
Post Tue Nov 25, 2014 9:33 pm
The ECU and OBC (if fitted) will be worth having.
BMW_E30vert
Post Tue Nov 25, 2014 11:19 pm
if it has a crack free dashboard it will be worth abit
HairyScreech
Post Wed Nov 26, 2014 1:05 pm
Where in the country is it? I could do with a few touring bits if you wanted to grab them.
lhd220turbo
Post Thu Nov 27, 2014 9:37 pm
Swindon, wiltshire
