I've been thinking about the 2.7 trick - will this work with a 1990cc block? Would need to change the final drive ratio, too, or have too many revs and too much fuel burn on a motorway. Any other mods required? ECU? Injectors, manifolds?
MONSPORT42 wrote (in another thread):
________________________________________
It's the fairly standard conversion using the eta crank from the 525e to give the longer stroke plus lightweight pistons, etc, etc. I also have a MAF conversion which increases throttle responses and helps to overcome the torque converter 'lag' a bit. The car's in the Members E30s - 2.7 section at the top of the page although I've had a few things done since the spec was written. If you go the the tuning route, go for torque enhancement rather than bhp alone. A lot of the obvious tweaks like induction and exhaust can push the available torque up the rev range and you can end up with little improvement in normal driving situations - i.e. away from the lights!
I'm no guru on the subject - this is just from my own (expensive) learning curve!
_________________
Six cylinder capacity increase to 2.7 ???
E30Adam
Yes you could use a 2.0l block but would need the bores enlarging to 84mm. You would need to change the final drive as the 320 usually has a 4.10 diff which is small case and would probably break. Acceleration would be rapid but it will just run out of revs too quickly.BlackCabrio wrote:I've been thinking about the 2.7 trick - will this work with a 1990cc block? Would need to change the final drive ratio, too, or have too many revs and too much fuel burn on a motorway. Any other mods required? ECU? Injectors, manifolds?
Have a search through the forum, there's a lot if info on this subject and most of your questions will probably be answered in other threads.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
BlackCabrio
Thanks - that's helped me make my mind up - I'll go for some less radical mods first.
Like the new sound system I put in this week. May the journey take longer!
Seriously, I thoink I'll start with the bbtb and chip mods. It's just I've got an exhaust manifiold stud sheared, and that looks like a headoff job, so my mind wandered into what else might be worth doing at the same time.
Karan
id highly recommend the 2.7 conversion, ive had one for nearly a year now and cant really fault it-just gota be careful in the wet
a good one will do 0-60 in 6secs flat which is nice
Karan
Karan
BlackCabrio
Impressed!
What does it do to the insurance premium? I'm paying a ridiculous 150 quid at present (over 50, rural location, 10k/year mileage, full ncb too).
Which is the cheapest thing about owning an E30 so far !
Karan
im 19 and insuring it as a 325, as the block no. still states 325i.
i guess ure premium would go up but not that much
if ure on msn i can send u a couple of vids that will show u what it can do
Karan
Karan
BlackCabrio
I'm not on msn, but I've got a fast connection at work - can u put them on your punniracing site? Just seen the spec of your car there!
Karan
that site is made and run by my uncle, but will get some up in the future, i think there's still limited space on there
