how tight is too tight?
xavier
I have bolted the downpipe to the exhaust manifold with just over 50 Nm torque. I do not want to go much tighter as I have a bad habit of snapping studs and bolts. Is 50 to low? is there a set spec? I cannot find one?
HairyScreech
Mikey_Boy
Now that's good advice above...! ^^^^
So easy to over tighten...
