Hi again Martauto
About the kickdown: My autobox gave up a few weeks ago and I needed to replace it. I thought it was a non switchable (non-electronic) as there was no computer in boot and no switch next to selector lever.
With the box out I saw that there was an electrical connector on the box (behind selector seal I think - facing backwards). So this was indeed an electronic controlled box. I guess a previous owner also replaced the auto with wrong box.
Anyway, the old box worked fine with 'normal' kickdown. What you should maybe look at is the kickdown cable of the electronic box. Pull on it and see if there is a resistance at the end of the pull, before you go to kickdown (sorry, bad explanation), like a non switchable has. My electronic did indeed have this 'normal' kickdown resistance and it worked fine without the electronics, but then maybe it was modified somehow?
Just make sure the kickdown switch/stopper beneath the accelerator pedal is set correctly.
Hope this helps. If there's anything else I'd love the chance to try and explain from my experience (Maybe something good can come from my ordeal
