is there anythig else on the car that is of any use to any E30 (most of us) or E34 (my wifes + a few others on here)
disemboweling a E32 735i tomorrow... what to keep?
gareth
apart from the obvious....
Turbo-Brown
- Boost Junkie
Ooooh!
Is that the one with the 25.4mm mastercylinder?
If it is, can I nab it from you Gareth?
gareth
well, not all done today but mostly there!!!
all i need to disconnect is the auto-box gear selector cable, the exhaust and the engine mounts, then it's up up and away!
a bit of a result really, it's got the full jistory to back up it's 102000 miles!!! the cooland was totally free of shite, all the tyres are good and it has some nice 16" alloys to sell on.
also has leather electric ajustable memory seats!!!!, aircon, cruise control, etc etc etc.
as it's on a mates grandads farm, i can't go too overboard stripping it so it'll be going with the seats in (unless they're worth huge money).
re the parts, the aircon was discharged and the belt was removed so it's likely to be stuffed...? i'll have the cruise control off as that looks easy enough. what needs removing to get the full OBC setup? no LSD unfortunately.
turbo-brown, will the M/C fit the E30 then? if so, mine is a bit leaky so i may have it for when i put my 4 pots on... if not then i'll whip if of for you.
the full set of pics is here:
http://photobucket.com/albums/v382/gare ... 1&multi=14
Nelly
- Gumbo
A1BMW325iSport
Hi Gareth, can i buy the glovebox please?
and the cruise control parts
also may be after the seats and door cards?
are you on msn?
are you on msn?
gareth
Nelly, sorry the (full!!!) toolkit has been baggseid by my wifes E34 sport... some fool took it all in the past...
A1BMW325iSport, PM on it's way.
Nelly
- Gumbo
m-dtech
- Unapproved Trader caution
you would get well over Ԛ£150 for the seats
gareth
really? do people actually upgrade these things?
do you know what else i'd need to remove to make an easily saleable setup? is there an ECU anywhere?
Stevin
Take the TB off and use the Butterfly for a BBTB on ur M20
Geeman
You got the centre caps for the rims...? If so, how much ar eyou looking at for them?
Giles
Giles
jaistanley
I can't remember if I PM'd you (damn that short term memory) but I wondered how much you would want for front calipers (and master cylinder if you're not using it)?
Many thanks,
Jai
Many thanks,
Jai
Toby_Unna
- Boost Junkie
i think he's putting whole engine in instead of the m20 mate it won't run very well without the TBStevin wrote:Take the TB off and use the Butterfly for a BBTB on ur M20
Geeman
Let me know about the wheels then fella.
Unless Andy's got some (who WAS going to phone me if he had some after meeting up at Donnington show! Grrrrr!)
Zayyan
Has it got MOT on it still? You could try flogging the plate.
jaistanley
Will those wheels fit my e30 with M3 running gear and H&R - 35mm springs? If so which tyres to use and how much for the wheels?
Many thanks..
Jai
Many thanks..
Jai
Geeman
*cough* Wheels *cough* Queue...
jaistanley
LOL.. sorry, my forum etiquette wasn't so hot there was it....
Any news on the brake calipers Gareth? Interested in selling them?
Jai
Jai
gareth
hehe! as toby said, the car is a donor for the engine conversion that's now well underwayStevin wrote:Take the TB off and use the Butterfly for a BBTB on ur M20
i don't have the cantre caps for the wheels unfortunately but the tyres are all pretty damn good. the wheels are all mint as far as i've seen. in need of a clean but no corrosion or curbing that i've seen at all. i'd take Ԛ£80 for the wheels to get them shifted. according to the wheel fitment guide, they'll be a good fit on a E30 M3. not sure on the tyre size that's best for the M3 though. i think these are 225/45/16 or something.
the m/c and calipers stayed with the car and it's all now probably in a 2 foot cube!!! Ripleys Autos in hastings have an identical one in at the moment though... the m/c fixings were different to the E30 one so wouldn't fit without a load of hassle (the bolt holes are 45 degrees out)
the number plate would have been good for someone with an Audi A6... however, the car had been without MOT for 2 years or so. a lot of work was needed to get it though making it uneconomical. (this was the original intention of the previous owner but it never happened, hence me getting it!
anyone interested in anything, then pm me. i have a spare rad, auto box, torque convertor and every ECU from the thing that i could find! (there's about a million of them!)
Andy335Touring
The LKM is a fairly common problem so should sell well on ebay.gareth wrote:every ECU from the thing that i could find! (there's about a million of them!)
jaistanley
Thanks for the info man..
PS Geeman : Sorry for trying to cut in on the wheels.. Somehow I missed your post!
Jai
Jai
gareth
so, this may well be a daft question... what's the LMK jobbie do? i got it (both of the similar jobbies under the rear seats) but i have no idea what they're for!
Andy335Touring
The LKM controls the front lights and was fitted in the same compartment as the engine ECU i think ? The two metal ECUs are for the OBC and cruise, again i'm not 100% sure though ?
The ones under the seat are for the rear lights and the central locking i think ?
Andy335Touring
oh and i'd guess you have an auto gear box ECU lurking some where as well ?
gareth
probably!
Geeman
Jai... no worries dude.
As there are no centre caps, I'll bow out gracefully, thank you.
