Hello All,
I now know Ant is no longer trading, can anyone direct me to someone who can supply me a similar 2.7 chip and at a later date remapping on rolling road.
I have nearly completed my m20 2.7 build and was supposed to get in contact with Ant for the chip and remapping.
I seem abit stuck .............
Need advice on where to get a 2.7 chip and remapping........
urfy
89 BMW E30 325i Sport
93 BMW E30 325i Cabriolet
89 Mercedes 190E 2.5-16 Cosworth
86 Mercedes 190E 2.3-16 Cosworth
96 Mercedes E320 CE Sportline
88 Nissan Bluebird ZX Turbo
89 Nissan Bluebird Executive Turbo
I can supply an M20B27 chip - what's your engine spec?
urfy
* m20/2.5 block decked 2mmSpeedtouch wrote:I can supply an M20B27 chip - what's your engine spec?
* eta 2.7 crank lightened & balanced at 8000rpm
* lightened & balanced flywheel
* 30mm conrods
* 84mm high compression pistons
* 885 cylinder head
* e21 323i camshaft
* adjustable venier cam pulley
* 64mm bored throttle body
* bigger 20lb injectors
* alpina 6 branch manifold mild steel
* e21 dogleg gearbox
PM sent.
jimbom30cab
- Tech 1 freak
The speedtouch 2.7 chip would be perfect for that. Its what I use.
urfy
What is the difference between atech 2.7 chip & speedtouch 2.7 chip?
Very little - slight differences in the program, perhaps...
jimbom30cab
- Tech 1 freak
I heard they were practically identical..
