clutch fluid leaking
fuzzy
hi folks, driving home last night i found a wet patch on my drivers side floor mat. the clutch fluid is dripping of the pedal. is there a common thing to look for before i go and tackle it?
magnumlove
it's probally your clutch master cylinder leaking.
gcorky
- Boost Junkie
89Cabreeo
That's exactly what it is based upon my unfortunate experience. If you're going to repair yourself you'll need a chiropractor when you're done because getting to the master cylinder is really awkward. Good Luck
89 325i Cabrio, Tucson, Arizona, USA
Take the driver's seat out. Makes working there a lot easier, and the loose change you find will go a little way towards paying for the new cylinder.
Ziggy
Blimey, don't get scared here - it's an easy job!
Just make sure you do the slave at the same time or you'll have problems again in the near future...
Job's easy, access is not.Ziggy wrote:Blimey, don't get scared here - it's an easy job!Just make sure you do the slave at the same time or you'll have problems again in the near future...
Slave won't neccessarily fail following a M/C change. It's when the slave fails and the M/C moves slightly further in the bore than it does normally that the M/C fails right after.
Ziggy
Fairy nuff - I'd just heard the stories of one causing t'other to fail & figured it was worth doing both...
Took me about 45 mins from start to finish, but seat-out's a good idea for next time
