Best Plugs
GZig
Post Tue Sep 30, 2014 12:00 am
What's the best running spark plugs for the 1987 325i M30 engine?
jmc330i
Post Tue Sep 30, 2014 7:58 am
M20 not M30 engine? NGK BPR6ES.
James
'91 325i Sport
'93 318i touring 16v
HairyScreech
Post Tue Sep 30, 2014 8:28 am
As above, every other spec of plugs I have tried has caused some sort of running issue.
Including the recomended zgr5 ngks. They caused a high speed miss I was chasing around for a while.
Never had a single issue with the bpr6es in years.
GZig
Post Tue Sep 30, 2014 11:41 am
Thanks for that James. I will see if I can find them here in the Philippines somewhere. It isn't that easy sometimes.
Gavla
Post Tue Sep 30, 2014 2:14 pm
Bosch W8LCR / Bosch W8LPR were the original plugs used if I am not mistaken.
HairyScreech
Post Tue Sep 30, 2014 2:30 pm
Gavla wrote:Bosch W8LCR / Bosch W8LPR were the original plugs used if I am not mistaken.
Yep, the plugs by the same part number you get today seem to degrade quickly and produce an idle hesitation/misfire.
Set of those in my free to anyone that wants them box.
Only thing I can put it down to is 10% eth unleaded vs the zero eth unleaded or 4 star that these would have been running on before.
That and a lot of these cars are now chipped with ageing ignition systems both of which will lower the margins of error available.
Gavla
Post Tue Sep 30, 2014 2:40 pm
Fair enough...was not aware of that...
reggid
Post Wed Oct 01, 2014 3:50 am
NGK seem like a lot better plug than bosch. You can use BPR5ES as well which might suit a lower compression/performance engine as it is a hotter plug. it might suit an engine that does lots of cold starts and doesnt run at full temp often due to short trips.
E30 325is with M20B31
zaust
Zone day release
Post Wed Oct 01, 2014 9:37 am
These are for the early high comp engine. They burn to hot for the later.
M30 Tech 1 Touring on gas.
reggid
Post Wed Oct 01, 2014 10:59 am
bosch WR8LC/W8LCR are for low comp engines its a hotter plug than the NGK BPR6ES which suits an engine with a little more compression
