Boot lock removal
Igotwood
Hi, trying to remove the rear boot lock, I've undone the bolts but can't seem to pull the externally black part off, any advice greatly appreciated, gonna try and upload a picture to help
bigbird76
Have you unbolted the solernoid from the framework, 2 7-8mm self tapper bolts? and unhook the little bar that joins to the lock?
Leigh
Leigh
Igotwood
Yep. Solenoid is removed, inclusive of arm. When I pull the cylinder from outside the boot, it won't pull away from the rear panel, is it just a case of pull harder ?
bigbird76
Cannot remember fully since i did my lock.
Just found this if it is any help?
http://www.e30performance.info/viewtopi ... =35&t=1590
Leigh
Leigh
