I was gonna say it is there , thanks dudeTodd130490 wrote:Nvm its finnaly showed up it was just blank before! Well done mate thats incredible!
new monster v8 no 4.0 here !!! Start up vid on page 28 :)
ross2009
yeah thought it might be best,maxfield wrote:To the floor, best way
the other reason why i didnt was just incase i pulled by the old bill having some thing sticking out of the wing, they would prob do me for it lol
ross2009
started on the exhausts this weekend got most of the way thro but ran out of materials so gonna have to order some more this coming week and finish it then, as ive gone 3" straight thro ive had to get it up as high as possible to avoid the ground
i think its high enough we will soon see
its not easy making a exhaust on the ground ive started to feel my age lol
the right side isnt supported here so looks lower
im trying to run the system like the original, and follow the original path of the standard exhaust
a little hammer action to get it under the rear beam
just got to order some more stainless now and get it finished
ross2009
bk up the garage again
finishing touches to the exhaust we now have twins !!!
also got a set of plug heat protector sleeves coz this thing is gonna get hot
craigieeb
You rebel you lol
but just think of all that weight just hanging off the poor turbos : (
and when you start going over bumps etc, something might give.....
M50 Turbo!!!
I shall say no more
ross2009
I'm sure they will be fine matecraigieeb wrote:You rebel you lol
Demlotcrew
Looking good.
Ive not read through every post, so excuse me if this is obvious, but unless you are running anything but derlin/solid beam and trailing arm bushes, your rear coilovers will bind against the wheel and the inner turret. You may have enough clearance in the droop possition, but due to the nature of the semi rear arm, the damper body will move closer to the chassis under compression. Just something to bare in mind.
Will this be at the Pod this year?
Andrew
Andrew
ross2009
I shall just forgive you now thenDemlotcrew wrote:Looking good.
Will this be at the Pod this year?![]()
Andrew
this set up isn't part of what I'm doing now
that set up has been on the car over 4 years now was running near on 450 bhp never had a problem , having said that yes the beam and the trailing arms are polybushed and have never rubbed or touched anything they shouldn't
I appriciate the concern lol
yeah I'm trying to push to get it done for pod although as I've said before will only be running a carb no injection yet and no boost, I'd like to put some miles on the engine for now
ross2009
im starting to have serious doubts wether this is gonna be done in time now im still having running problems ,
and struggling to keep it running theres some thing that isnt right we think its fuel starvation but not sure,still too much to do and not alot of time to do it
might even get trailered there just to be there
ross2009
its more the fact that its not running right which is pissing me off there simple engines there nothing to them but cant figure out whats wrong, plus i still need other turbo, prop starter tax mot etc etc feeling deflated
cypriot_boy_2k7
- Contact:
Excellent progress man. Keep your head up!
ross2009
having real running problems at the mo it idles fine, as soon as you see it any fuel it just spits bk and dies just don't have a clue why
cypriot_boy_2k7
- Contact:
Are you using management?
cypriot_boy_2k7
- Contact:
Any pics
cypriot_boy_2k7
- Contact:
Spark blowout? Due to little spark?
