HELP!!!!! vibration at steering wheel at 50ish
ih chaps i have a bad vibration at 50, i have balanced front wheels to a fine balance, checked ball jionts,track rod ends, mounting bushes on wishbones,checked run out on front disc ,tyres are new, pressures are spot on, any ideas or other points i might have missed
have you got or do you need spiggot rings on the alloys??
also have the rears been balanced??
have heard they can cause shake
www.oldskoolfantasy.co.uk
- Brianmoooore
Checked your control arm bushes or changed them? I've known vibrations to be caused by ones that looked perfectly serviceable.
Dan318-is
what offset are the wheels?
all the vibration problems i have ever had, an tehre have been many off them, have been due to the wheel having an incorrect offset. Even when i had wheels with et 30 on my bmw they wobbled at 80
et25 an its job done
- Brianmoooore
M3 control arm bush.TINSNIPS wrote:does anybody do an upgrade bush set,somthing like power flex for the control arm bushes
Ziggy
What sort of spigot rings have you got? If they're the plastic ones, they can deform when you put the wheel on. You can get metal replacements for notalot...
- Brianmoooore
M3 ones are solid rubber, without the cut outs. Available with the hole for the control arm in the middle or with it offset towards the edge for increased castor.TINSNIPS wrote:whats the diffrence between std and m3 complanice bushes
i have metal rings on but we did notice some corrission build up between wheels and disc. have not had time to road test yet, due to fact i took the bosses mr2 turbo home tonight to test out the nos system, had to change under pants ,bit dangerous for road use,to many idiots on road plus car to quick without nos running.
